Question about Ricoh 3320L Laser Fax
We receive a partial or a blank page for incoming faxes followed by an error report pade with a 00-23 Quick Service Code. Can you help?
  • 165 Answers
Too many errors during reception
check the line 1st
too much noise on line
if its all the time from different ppl my guess is its ur end
connect a phone dial 1 and listen to the line if u hear any noise then its u
Posted on Nov 10, 2010
Cannot recieve fax on hp pro 400
HI,
Set Fax Forwarding:
You can set your product to forward incoming faxes to another fax number. When the fax arrives at your product, it is stored in the memory. The product then dials the fax number that you have specified and sends the fax. If the product cannot forward a fax because of an error (for example, the number is busy) and repeated redial attempts are unsuccessful, your product prints the fax.
If the product runs out of memory while receiving a fax, it terminates the incoming fax and only forwards the pages and partial pages that have been stored in the memory.
When it is using the fax-forwarding feature, the product (rather than the computer) must be receiving the faxes, and the answer mode must be set to Automatic .
  1. From the Home screen on the product control panel, touch the Fax button.
  2. Touch the Fax Menu button.
  3. Touch the Receive Options button.
  4. Touch the Forward Fax button, and touch the On button.
  5. Use the keypad to enter the fax-forwarding number, and then touch the OK button.
If not solved i share a link please visit and follow instruction.
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c03266760-14%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1403114393261.876444892.492883150
Thanks,
HP Phone Number
Jun 18, 2014 | HP Photosmart C6180 All-In-One InkJet...
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
How to retrieve 1 week ago fax history from brother 2280 fax machine
Printing reports
How to print a report
1 Press Reports.
2 Press ? or ? to select the report you want.
Press Menu/Set.
-OR-
Enter the number of the report you want to print.
For example, press 2 to print the Help List.
Following reports are available
1.Transmission
Prints a Transmission Verification Report for your last transmission.
2.Help List
Prints the Help List so you can see at-a-glance how to quickly program your machine.
3.Quick-Dial
Lists names and numbers stored in the One-Touch and Speed-Dial memory, in numerical order.
4.Fax Journal
Lists information about the last incoming and outgoing faxes. (TX means Transmit.) (RX means Receive.)
5.User Settings
Lists your settings.
6.Network Config (MFC-7225N only)
Lists your Network settings.
Jun 11, 2011 | Office Equipment & Supplies
I receive 1 page of an incoming fax but then the next page is a fax call report saying comm error 232
Try this...
a) changing the Error Correction Mode (ECM) to OFF
b) disabeling V.34 option
steps for
a) Fax setup -- All faxes -- Error correction -- OFF
b) Fax setup -- All faxes -- V.34 -- disable
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | HP LaserJet 3050 All-In-One Printer
Been receiving blank pages on random incoming faxes. Multiple error codes, but the one I can't find in the manual is code 212. This error code keeps reoccuring along with others.
Press the following keys:
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for the machine to reboot.
Jan 08, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Incoming Fax is blank
PRESS REPORTS IT WILL PRINT OUT A HELP PAGE LOOK AT THE SUB MENUE ON THE HELP PAGE MENUE SELCTION 3 FOLLOW THE PROMPT TO TURN ON THE RECEIVE OR IT MAY SAY EASY RECEIVE . GOOD LUCK BROTHER TECH / I HAVE THE SAME MACHINE AT HOME GOOD LUCK
Dec 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Ricoh 3320L Laser Fax Logo
660 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
