Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
What cause a error report Unable to print 70? and how do I solve problem. Many thanks Susan
  • 47 Answers
These mean the machine does not work due to a paper jam or some sensor problem. try to clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip (clear strip of plastic) located behind the head.
Posted on Nov 10, 2010
I need cleared (print unable 70) brother 3040cn
unable to print 70 is a Head problem or purging unit problem error code... better contact brother service
Sep 27, 2013 | Office Equipment & Supplies
We are getting an error code 70 - unable to print. We just replaced each of the ink cartridges.
Hello and welcome to FixYa!
If you are facing the error code 70 on brother printer it usually means
the printer does not work due to a paper jam or some sensor problem. It also may be due to dirty encoder strip or may be the encoder strip is out of position.
To solve this problem:
Remove the top cover and check inside for any possible piece of paper or dirt on the right or left most part of the carriage that is preventing it from moving. Clean it very carefully and turned on the printer, if still error code exist then
clean the encoder strip behind the printer head and if it is out of position,fix it on right position.Your problem will be solved.
For further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Jul 14, 2011 | Brother Office Equipment & Supplies
Printer' LCD: print unable 70. How to repair ir?
The machine has a mechanical
problem.
-OR-
A foreign object such as a clip or
ripped paper is in the machine.
Open the scanner cover and look on the left,
middle and right hand side under the covers for
foreign objects and paper scraps. Then, disconnect the
machine from the power for several minutes and
then reconnect it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | Brother MFC295CNAll-In-One InkJet Printer
Dear all here i am anil kumar from india i have MFC brother printer DCP-195C but i have facing problem when i print the page the printer show print unable error 70 please solve my problem thanks...
Error 70 normally is a paper jam or something else that is stopping your print head moving correctly.
Open the covers, have a look, and after clearing the jam you must power off and on the machine.
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper is stuck in the machine
- Mechanical malfunction
The most common cause of this issue is dirt on the encoder strip.
Oct 27, 2010 | Brother DCP 165C Compact Color Inkjet...
Eliminate the transaction report
To eliminate the transaction report, perform the following:
  • Press Function button once
  • Press down arrow 3 times
  • Press right arrow > once
  • Press 5 "Never Print"
  • Press "STOP"
This will eliminate ALL transaction reports. There are 5 options for this function.
  1. Always Print
  2. Error/Memory Print (memory errors only)
  3. Send Only (prints only on sent fax)
  4. Error Only (prints only when there's an error encountered)
  5. Never Print (eliminates all transaction report printing)
This should solve your problem. Please post back with any questions and/or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error code print unable 5A on a Brother HL4070CDW
On most printers that are manufactured today have an error chip built onto the motherboard of the printer. If your printer experiences an error. It will register it on on the chip. You will continue getting the error because it needs to be cancelled. To cancel this error follow the instructions below:
1) Turn print on
2) Unplug the printer from the power
3) Wait at least 70 seconds
4) Plug it back in
The error should be cancelled
From Brother's website:
Print Unable ##:
Turn off the printer. Wait a few seconds, then turn it on again. If this does not clear the
problem, call your dealer or a Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe Diaz
May 10, 2009 | Office Equipment & Supplies
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
350 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
