Question about Compaq Armada M700 Notebook
Shutting down without warning
Somebody gave me a Compaq Armada M700 PC Notebook, Whenever I switch-on the laptop it runs smoothly up to 5-10 minutes, means it was already in the display of the wallpaper, when the fan of the heatsink stops after a minute it just shut down on its own. Sometimes it doesn't open at all, Is it normal that the fan stop when the laptop working?
  • darios Jun 18, 2008
    thanks
    thanks pagebor
    Genius:
  • 2,785 Answers
Dear darios
its not normal that the fan stop.
plz check your powersupply unit.
Posted on Jun 17, 2008
  • Rajkumar Bordoloi
    Rajkumar Bordoloi Jun 18, 2008
    dear darios
    you are always welcome to post your problems
How do i get to the recovery partion on compaq armada m700
Dear Lizanne,
To get to the recovery partition on your Compaq Armada M700, turn on the notebook and press F11 repeatedly until "Windows is loading files..." displays on the screen. Then, follow the on-screen instructions.
If your notebook originally came with Windows XP or an earlier version of Windows, try pressing F10 to enter recovery instead of F11.
Hope you may find these instructions useful!
Best regards,
Miguel L. Martins
May 16, 2014 | Compaq Armada M700 Notebook
My Compaq Armada m700 will shut down on it's own. When I try to restart it the screen is really messed up. If I let it sit and cool down it will then reboot okay. Is this because it is getting too hot...
It's either heat or virus related. 1st clean your vents with a can of compressed air. 2nd listen to make sure your fan is spinning. If these are all clean & working then run a good anti-virus program to make sure your laptop is not infected. If heat is still a problem you can purchase a laptop cooling pad for around $30. Hope this helps.
Oct 20, 2009 | Compaq Armada M700 Notebook
Installing wifi in Compaq Armada m700??
yes, aslong you have USB port or PCMCIA card slot
if your compaq armada m700 is the p III series it's alot better
Jan 25, 2009 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Laptop shuts down
check the timer setting and set it to always on
Mar 18, 2008 | Compaq Armada M700 Notebook
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Cant find wireless switch on laptop compaq armada m700
look for swicth on computer it self switch it over to u see it turn on sumware ok
Feb 11, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq M700 Ram Upgrade the second
i can find no spec on this but,if your notebook can take upt 576MB of memory, i would expect 2 x 256MB to be the max, as installing 1 x 512MB would be doubling the capacity allowed by one module slot.
Oct 01, 2007 | Compaq Armada M700 Notebook
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
132 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
