Question about Roper RAX4233PQ Top Load Washer
I have a roper washing machine. How do I clean the lint out? Marks are all over my clothes. I have tried cleaning the inside with orange cleaner, tried rinse load with bleach. Nothing works
  • Roper Master
  • 8,220 Answers
You might have to do a DEEP clean of this washer. This video shows how to remove the inner tub:
Direct drive washer tub seal replacement.
Posted on Nov 10, 2010
LG Steamwasher after wash cycle left dirty marks on clothes.
You may have some detergent residue inside the tub assembly. You should run a tub clean cycle and use some washing machine cleaner. You can get that at any hardware store. If you don't have a tub clean setting, use the sanitary wash cycle without any laundry inside. You must use the hot water setting for this to work. If you haven't done this in a long time, you may have to run this cycle at least once a week for a month to really clean the machine properly.
Jun 23, 2011 | Washing Machines
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
How do I removethe lint? Clothes are coming out with fluff...
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
Nov 05, 2009 | Roper RAX4232KQ Top Load Washer
Roper model sm 8280871. Machine cleans well, but leaves lint on some of the clothes. Is there a filter or something that needs to be cleaned/replaced?
no filter that i know of but i would suggest a boil wash with nothing in tub to try and remove any caked debri etc in drum,hope this helps
Jun 21, 2009 | Maytag PAV2300 Top Load Washer
Roper Wash Machine Model # RAS8333RQ4
check the switch under the door , it could be damaged , check with a multimeter at OHMS setting , if there any reading then switch is OK , if not try to clean it up with tuner cleaner , you can purchased at RADIO SHACK.
Dec 17, 2008 | Roper RAS6233KQ Top Load Washer
Roper top load lint filter
it has a self cleaning filter mounted under the tub. if you want to clean out the tub and filter thoroughly then:
  • run a cycle with no clothes using hot water and a gallon or two of bleach.
  • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
  • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
Jun 08, 2008 | Roper RAS8445KQ Top Load Washer
To much lint on my clothes after washing
try an emptyhot wash with some limescale remover in approx quater of a litre, let it run all the way through the wash then put on another rinse to clear out system. check the next water fill for any debris/lint left.
Jun 16, 2007 | Kenmore 22442 Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
240 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
