Question about Toshiba 26 26AV502R 26 in. LCD HDTV
26av502r - blowing fuses. i disconnected the board from others and still blows fuses. bty, what rating is the fuse?
    Genius:
  • 1,622 Answers
You can do this by yourself all you have to do is to open the back cover of the television to check the faulty components. to fix you must have basic knowledge on electronics .
The fuses are there to protect the set from catching on fire in case there's a short circuit inside the set. Now in some cases an intermittent short can work after you replace the fuse but if its burnt black or brownish, there's a circuit inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifiers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted.
I hope this help in solving the problem.....
Posted on Nov 10, 2010
Blowing fuses on rheem rtgh 84dv
Call service technician
Check polarity of 120 volt outlet
Call Rheem for new PC board
If the 3A glass fuse located on PC board is blowing, then something is drawing too much current or shorted on board... problem is probably bad PC board
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 12, 2014 | Rheem RTGH-84DVN Indoor Direct Vent...
Wy fuse keeps blowing
Fuses blown when an overload occurs. More often than not caused by a short circuited transistor in the main amp section. Possibly also on the power supply too.
May 22, 2014 | AMC Multimedia CVT-2030 2-Channel...
My whirlpool dryer keeps blowing the fuse for heating. The dryer will still tumble but once stopped, won't start until the fuse is replaced. We've cleaned the whole thing out and even set up a different...
I would check the outlet as it sounds like one of the wires is off/shorted. Here is a website that may assist you, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 01, 2010 | Kenmore 63932 Electric Dryer
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
My fuel ecu fuse keeps blowing?
Unplug the O2 Sensor and see if it blow again. If it does not the sensor is faulty. Replace with a new one. BTY its in the exhast system.
Jun 13, 2009 | 1993 Jeep Wrangler
The dash board lights are not working and the
hi mate if you keep blowing fuses disconnect your front fog lights and try again if your dash lights work then a bulb has failed and gone to earth if it still blows the fuse disconnect the dahs pod (clocks) and reconect the fog lights if it does not blow the fuse the it probably is the dash pod or something associated with the pod hope it helps
Apr 02, 2009 | 1994 Subaru Impreza
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
Proform 570 blowing fuse
there are generally two control boards, I am assuming you looked at the lower one. I would first disconnect the power leads at the board and see if it still blows the circuit breaker (fuse?). If it does the check wiring for short. If OK then reconnect power leads and then disconnect all other wires (plug-ins) to the board and try again, each time plug a connection in and retry. (remember to disconnect power each time). I have a feeling the smoke got let out of this lower board and may need replacement. hope this helps
www.twincityrepair.com
Mar 01, 2009 | Proform 575 Crosstrainer Treadmill
FUSE BLOWS EVERTIME I TURN MY TV ON. I CAN REPLACE THE FUSE AND DISCONNECT THE FLYBACK FROM THE CRT,TURN THE SET BACK ON ,CHECK THE FUSE IT WOULD STILL BE GOOD,BUT WHEN I REINSERT THE FLYBACK AND TURN THE...
Possibly a resistor that's becoming defective... it's changing value thus increasing current. like if the resistor has a rating of a 10k Ohm and now it's changing to a 30K Ohm and the current (amps) is supposed to be around .50Amps and now it's rising to .75Amps or higher, so it would blow the fuse so as not to further damage any other high voltage or sensetive component. Is the fuse you are replacing the same as rated for the tv? ie; 250V 1.25Amp FB (fast blow) or SB (slow blow) it should say on the circut board where the fuse plugs into.
Jul 17, 2007 | Zenith C27A24T 27" TV
Toshiba 26 26AV502R 26 in. LCD HDTV Logo
293 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
