Question about Intermatic Inc. ST01C Digital In-Wall Timer
Problems with Setting different "
You posted under ST01C timer.
Yes the ST01C manual is confusing at the exact point you are stuck at.
Open following page to see step by step plus illustrations that show the confusing part of manual:
http://waterheatertimer.org/ST01C-program.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 07, 2011
Timer model#28486
1) Copy following link to help identify same-similar timers with dawn-dusk selectable time Off.
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Stanley-Westinghouse timers have 1 year limited warranty, but unknown who you contact for warranty service.
Buy Woods, Intermatic, or GE timers instead.
3) Do not exceed watt rating.
Make sure bulbs are operable.
Try different bulb in same timer output to see if outlet has power.
Buy timers at local store for ez return and exchange.
Try on different outlet.
Test outlet for 80% rated voltage.
Dec 15, 2012 | Hardware & Accessories
Utilitech #0192773 setting the timer for not working
I do not have repair for defective timer.
Open following link for clear large-print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment about part of manual that does not work, for possible additional help.
1) Timer replaces single-pole light switch only.
2) Timer does not have a battery and must be wired correctly before programming can take place.
3) Choose either dawn-dusk or programmable on-off:
Timer can be set for dawn-dusk operation
-OR-
Timer can be set with 7-day on-off functions of your choice
Aug 18, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have an Intermatic ST01C timer. Works great. I just noticed that I cannot set the DUSK time past 9:11pm. Any minute before that is fine such as 9:10pm but I wanted to set it to about 9:15pm. It has...
Call Intermatic.
You can set dawn-dusk parameters a bit longer or shorter than pre-programmed dawn-dusk times.
There is a limit to how many minutes you can add or subtract to pre-programmed times, and I'm not sure how many minutes exactly.
All astronomic timers have limited number of additional minutes, and folks write to fixya occasionally about wanting to extend the limit. But there is no work-around unless you choose to set fixed on-off times instead of using astronomic feature.
If timer begins to malfunction, you reset timer and change CR2 battery, and then reprogram the timer.
Instruction manual has troubleshoot checklist.
Timer comes with 1 year limited warranty.
Open following links for ez instructions, wiring diagrams, and battery illustration:
Jul 29, 2011 | Intermatic Inc. ST01C Digital In-Wall...
In setting the sunrise -sunset do I have to program it for every day of the week, or just the first time.
The answer is no. You can program dawn to dusk for whichever block of days you choose:
Individual days Mo thru Su
M-F Monday thru Friday
WDK for weekend
ALL for all days of week
Step-by-step instructions for ST01C dawn-to dusk appear on following page:
1) Press + to display DUSK or DAWN for program 1 ON
2) Press ON/OFF to display days you want Dawn-Dusk to operate.
For example ALL is all days of week
3) Press ON/OFF and display will show SAVE
4) Next you set program 2 OFF and be sure to select same days for OFF that were selected for ON.
Jan 20, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
http://waterheatertimer.org/Aube-timers.html
Utilitec 0192773 with 7-day and astro dusk to dawn
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
http://waterheatertimer.org/GE-timers-and-manuals.html
Woods 59018 in-wall
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to set utilitech wall timer for dusk/dawn settings
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
On the sunrise/sunset setting the sun is always dark as if for night. How do i get to the light cycle ?
You posted under ST01C Intermatic timer.
The Intermatic has a battery
If you have another timer, such as the Utilitec, please answer and I will help you with that problem.
Here is the ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
If I understand correctly, you are programming the timer for the first time.
And you want to set timer for sunrise/sunset.
I have a ST01C in my hand right now
Section 6 says you can select astronomic function which is dawn-to-dusk
I notice that when you want to get to the Dusk cycle, you press ON-off button until Dawn shows ... and then press + key and Dusk shows on display
Answer back. These timer manuals are hard to figure out sometimes.
Oct 24, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have the DT620CL and want to disable the Dawn and Dusk settings.
See "Changing Program Times--Skipping and ON or OFF Event" in the attached manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt620cl.ashx
Find the Dawn or Dusk program time and follow the instructions in step 5 (Turn the selector knob until SKIP shows
in the display and “-- --” replaces the
time (Fig. 17), then press PROG to accept
the new setting.)
Nov 19, 2009 | Intermatic Hardware & Accessories
Setting
manual for HB51RC
http://www.intermatic.com/%7E/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
See timer at Amazon
http://www.amazon.com/Intermatic-HB61RC-Digital-Outdoor-Control/dp/B00004W4X5
Plug timer into outlet
Plug lights into timer
Timer turns on automatically at dusk + override lets timer run during daylight hours
Timing cycle repeats each 24 hours
Use selector button to set timer
Timer must be reset after power outage or after unplugging timer.
Push selector button and choose one of following
F > Lights are OFF
O > Constant ON
1 through 9 > timer turns ON at dusk and turns OFF 1 to 9 hours later
d > timer turns ON at dusk and OFF at Dawn
1. through 9. > timer turns ON immediately and then turns OFF 1 to 9 hours later
Maximum wattage 1000
50 mini-bulb-string of Christmas lights is 25 watts
Oct 02, 2009 | Intermatic Outdoor Timer/Photo Control...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
204 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
