Question about Ubi Soft Entertainment Cold Fear for Windows
Can't find file : EnvVars.cfg - Ubi Soft Entertainment Cold Fear for Windows
How to delete all configurations of the S2300?
To delete all the configurations, delete the vrpcfg.cfg file from the flash memory, and then restart the Huawei S2300 switch. The vrpcfg.cfg file cannot be deleted when it is running because it is used as the system file. To delete the file forcibly, perform the following steps:
1. Restart the Huawei S2300 switch and press Ctrl+B to enter the BootROM menu, and then enter the default password huawei.
2. Press Ctrl+Z to enter the hidden menu, and then select option 2 to enter flash memory.
3. Delete the vrpcfg.cfg file from the flash memory, and then restart the device.
More related:
Huawei S2309TP-EI-AC
Huawei S2309TP-EI-DC
Huawei S2309TP-PWR-EI
May 17, 2017 | Cell Phones
Ya if i only could reload win7 and yes u will lose all info on hdd even the dummy password he put on to lock hdd amazing only thing it wont reload windows
Step 1:
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Step 2:
For Windows users who switch and upgrade from Windows Vista, one difference will be immediately noticeable when installing or upgrading to Windows 7, i.e. Install Windows 7 setup wizard no longer prompts or asks for user selection of which edition of the operating system to install. Instead, each Windows 7 DVD disc or Windows 7 ISO image will automatically install the preset specific edition which it's confined to.
Although Microsoft does not provide an universal "one disc rules them all" Windows 7 installation media, however the function is indeed supported. User just need to delete and remove the ei.cfg from any Windows 7 ISO disc image to convert the image into universal disc of any edition Windows 7 installer. For user who has the ISO image of Windows 7, and wish to make it an universal installer for any and all supported editions of Windows 7, as shown in illustration below, now has an easier way to modify the ISO. Instead of manually unpacking and extracting the content of ISO image (or copying files from DVD) to HDD, deleting the ei.cfg and then repacking or rebuilding installation files back into ISO to burn, user can now eliminate troublesome procedures by making use of "ei.cfg Removal Utility". clip_image001.jpg The ei.cfg Removal Utility is a simple tool that will disable the ei.cfg from any Windows 7 ISO disc image, thereby converting the image into a "universal disc" that will prompt the user to select a preferred edition during setup. ei.cfg Removal Utility works directly to patch the ISO image, by toggling the deletion bit in the UDF file table to instruct the operating system to ignore and remove ei.cfg, or treat it as if it does not exist. Best of all, ei.cfg Removal Utility can reverse the patching to restore the ISO disc image to its original state when the tool is been used to apply on a disc image that previously been patched by the utility. ei.cfg Removal Utility is a standalone portable app, and thus no installation required. In fact, the program does not have much user interface. After selecting the target Windows 7 ISO, the disc image will be patched right away. So make sure a copy of ISO backup is done. Download ei.cfg Removal Utility: eicfg_removal_utility.zip
Feb 14, 2013 | Computers & Internet
Error loading 0004f220429c.cfg
This means the phone cannot find its <mac>.cfg file on the boot server, and does not have one loaded in its own flash memory.
You will need to configure a boot server to host the SIP software, BootROM, and all the config files (these are included in with the SIP software).
You can download these from Polycom's product support page:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 18, 2009 | Polycom SoundPoint 330 IP Phone
COD 1.3 build win-x86 Mar 2 2004 -----
For this you have to back up your file and they it can work or you can restore the computer that day when it was good . Just cilcke on Strat then click on programmes and accress and system tools and and at last clike on system restore ...
Jul 11, 2009 | Computers & Internet
Cant' play the game : Rap[ala Pro Fishing (Activision)
A. There is a known fix to the problem that you have experienced and if you follow the instructions below, you will be able to resolve it. What you're going to need to do is find the file called 'Console.cfg'. This is located in your game's install folder (My Computer -> C:\Program Files\ActivisionValue\MagicWand\Rapala\Rapala\Cfg) inside the \Cfg folder. It might be easiest to just do a search from the start menu for 'Console.cfg'. Once you find that file, open it up with notepad or wordpad. You will see a series of lines, the 5th line says: "addvar r_windowed int; r_windowed = 0". You're going to want to change that to: "addvar r_windowed int; r_windowed = 1". Towards the bottom of the file (scroll down) you'll see two lines: "addvar rWaterReflect int; rWaterReflect = 1" and "addvar rWaterRefract int; rWaterRefract = 1" . You're going to want to change those to: "addvar rWaterReflect int; rWaterReflect = 0" and "addvar rWaterRefract int; rWaterRefract = 0". Make sure you save the file and that it asks you to replace it when you save. Then you can start the game. It will not take up the whole screen, but you can fix that by going into the options menu from the main menu and increasing the resolution.
Apr 08, 2009 | Activision Rapala Pro Fishing for Windows
Counter-strike 1.6
see if your mouse has left hand properties
control panel set up mouse OR
If you cannot switch your weapon to the right-hand, please go to your advanced video options and change the renderer to either OpenGL or Direct3D. The software renderer does not support right-handed models.
You can select left or right-handed models by typing the following command into the Console:
  • To use your left-hand: cl_righthand 0
  • To use your right-hand: cl_righthand 1
You may wish to create a userconfig.cfg file with the cl_righthand 0 command if you would like to keep the left-handed setting. Please follow these instructions to create a user.cfg file:
  1. Locate the subfolder in your game folder that holds the config.cfg file
    For example, you can find the config.cfg file for Counter-Strike at [Steam installation directory]\steamapps\[your Steam account name]\counter-strike\cstrike\config.cfg
  2. Create a new text file in that directory called userconfig.cfg
  3. Open the file with Notepad and enter cl_righthand 1 (to use the right-handed model) or cl_righthand 0 (to use the left-handed model)
  4. Save the file
  5. Launch the game to test the user.cfg settings
Jan 21, 2009 | Sierra Online, Inc. Half-Life:...
HE tratado de instalar CALL OF DUTY , Y PIDE ARCHIVO OPENGL
you need to uninstall the game and reinstall and make sure your disk is clean i have had this myself
Nov 16, 2008 | Tablets & eReaders
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Faulty DFL-700 image - missing FWCore.cfg
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
Download Link:
http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
May 05, 2008 | D-Link NetDefend DFL-700 Firewall
Ubi Soft Entertainment Cold Fear for Windows Logo
521 people viewed this question
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
