Question about Dell Inspiron 530 Desktop Computer
My Dell Inspiron 530S beeps three times when powered up, the USB ports have no power and the monitor isn't getting a signal. Any suggestions?
  • 92 Answers
Beeps during startup/POST means you have a hardware failure that is stoping the computer from starting up normal. 3 beeps means you have faulty RAM. You could trying removing a stick if u have more then 1 installed, however replacement is ideal. RAM is highly inexpensive and is a DIY project that would take less than 10 minutes to complete. However if your computer is under warranty I suggest calling dell and letting them deal with it.
Here is link to beep codes for future reference
Let me know if you need instructions on to swap out RAM, I would gladly assist, please rate
Posted on Nov 10, 2010
  • Nickallsta42 Oct 06, 2011
    How do I Swap out the ram?
Beeps twice then pauses and beeps twice again(repeats) and wont boot
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Dec 31, 2012 | Dell Inspiron 530s Desktop Computer
Dell inspiron530 won't boot and beeps four times stops and beeps again
The Beeps are a beep code 4 means you have a ram read/write failure. Or a possible motherboard failure in that case you will need to contact Dell or replace it yourself.
Oct 01, 2012 | Dell Inspiron 530s Desktop Computer
What does two beeps on a dell Inspiron 530S mean and how do you get it out of power saving mode?
Power off. Wait a full minute. Discharge static from your hands by touching exposed metal part of chassis (case). Open your case and re seat memory chips.
Jul 07, 2012 | Dell Inspiron 530 Desktop Computer
Dell 530s usb port want work
In device manager under USB you should see 4 different controller entries => For each one, Rt click to the controller and choose Uninstall (no worries driver files themselves are on your computer) => After ALL 4 have been uninstalled, from top menu items click Action -> Scan for hardware changes => The drivers will be reinstalled. When done try again
Power reset If above doesn't help unplug all the power cables. This means unplugging the monitor cable as well as computer power cable. Wait about 15 minutes. Then plug back in and try again
Sep 01, 2011 | Dell Inspiron 530s Desktop Computer
My pc monitor is showing a box say dmps suspend status
The DPMS standard (Display Power Management Signaling) was developed to extend the useful life of PC monitors as well as to conserve the relatively high amount of energy used by monitors when not required.
In brief terms it works as follows.
The DPMS compliant video controller and the DPMS compliant monitor use the Horizontal sync and Vertical sync signals to control the power mode of the monitor. Because there are 2 signal lines, it allows 4 modes of operation. Normal, Standby, Suspend and Off.
Go to your power management source located in the control panel and make the needed adjustments.
Dec 24, 2010 | Dell Inspiron 530s Desktop Computer
How do i unlock my dell keyboard?
Dell Inspiron 530s keyboard unlock
Is the keyboard usb or ps2? If its usb then try another port. If its ps2(Green) then power down the pc by holding in the power button for 8 to 10 seconds. Pull the plug and make sure no pins are bent. Plug it back in and boot back up. This should fix the problem if its ps2. Regards
Jul 06, 2010 | Dell Inspiron 530s Desktop Computer...
Dell Inspiron Vostro 530s won't boot.
I work for Dell, If the power button led light is flashing amber or amber (the Power supply is faulty) The Yellow light you saw inside the motherboard is the "Flea Light" (that is one way you could check if there is still power on the motherboard). Since the motherboard was replaced there are a few more things to check:
1. Video card (integrated or expansion)
2. Monitor (Make sure it displays self test feature when the cables are removed)
3. Monitor Cables (VGA / DVi)
4. Power Cable on the Monitor (try a different cable)
5. Power Supply (you already checked, but i suspect this is causing the problem)
Hope this helps.
Mar 16, 2010 | Computers & Internet
Beeps when turned on monitor says no signal and fans do run
How many times does it beep? If it beeps seven or so times, it's your video card. If it only beeps once or twice, can't remember for sure, it's memory problem.
Dec 31, 2009 | Dell Inspiron 530s Desktop Computer
Dell Inspiron 530 Desktop Computer   Logo
1,273 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
