Question about Echo Gas Blower 135 MPH390 CFM Blower PB250
My Echo PB-4600 lost a bearing on the crank shaft. The parts are available. Is this an easy fix or should I just thank the blower for its' 14 years of sevice. I bought the Echo PB775T to replace it.
  • 297 Answers
WOW 14 years, I would give it a respectfull goodby. and spend $139.00 and keep going. The blower would have other "Age" related issuses even after you pulled all of the plastic off, removed carburetor,exaust and cylineder/head then you remove the flywheel and impeller then to split the crankcase and pull the crankshaft out replace the bearings. And all to reverse the steps wondering if you should have replaced the needle bearings and the wrist pin hopeing that the sealant you used on the crank case has sealed correctly, and are the piston rings really worn out or are they supposed to look like that. Then finally getting it all put back together only to find that it wont start because you dont have any spark or back firing because the coil is not adjusted correctly.
You have recieved GREAT service from that old blower. Good job.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 11, 2010
Echo leaf blower pb-261l part#10491011410 the part broke between the backpack and blower got the part off the backpack one is still in blower how to get that out
Take apart the blower and then re-assemble it according to the manual then you should be able to find and fix the problem.
May 18, 2017 | Echo Garden
Not easy to strart and lost power
check for plugged exhaust port. then carb adjustment and then new carb. fresh gas with red armor 2 cycle oil never hurts...
Dec 03, 2013 | ECHO, Inc. PB-251C Handheld Blower
Echo leaf blower has gas coming out of the exhaust
My ECHO dealer told me that my PB-251 was not worth repairing because it was 2 years old an to buy a new one... It will not be another Echo. So much for the 5 year war. I'm not very happy........
Aug 26, 2012 | ECHO, Inc. PB-251C Handheld Blower
Is there a way to fix a echo PB 4600 cdi module?
Hi, no sorry, it has to be replaced. Regards Phil.
Oct 31, 2011 | ECHO, Inc. PB-251C Handheld Blower
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
ECHO PB-250 blower new used one time carb.needs adj.can this carb.be adjusted
Your machine has a rotary-valve diaphragm type carburetor. These carburetors typically only have an adjustment for the IDLE speed with an available option to control the main jet with an adjustable mixture needle.
http://www.echo-usa.com/Products/Blowers/PB-250
Here is the info on the Zama rotary-valve diaphragm carburetor.
http://www.zamacarb.com/prodlist.html#RB
Some have a small adjustment needle in the center pivot of the rotory part, under a brass plug...but most have nothing. Many end users and techs are complaining about the non-adjustable carbs. They are made this way to meet the more stringent EPA emissions codes that are getting tougher each year.
Jul 03, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I lost my manual. What is the gas to oil ratio?
Your manual can be found here:
http://www.echo-usa.com/documentation.asp?Model=PB-251&lang=E
Please download a copy, IPL too.
Page 21 - Fuel Oil Ratio- 50:1 (2.6 oz/ 1 gal)
A rich mixture often causes hard starting.
Oct 29, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo Gas Blower 135 MPH390 CFM Blower PB250 Logo
246 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
