Question about PfaFF Hobby 4260
Hobylock 794 serger right looper needle position...I took it out to thread it and can't get it in the right position to sew correctly
I had the same problem. the last resort was go get a professional repair person. i had to replace the whole needle shaft. then the tension feeds were looked and i have never been more satisfied.
Posted on Nov 20, 2010
Threading the 634d took me over 8 hours to get the thread to go though the right needle. Is there an easier way?
Most new serger users have trouble threading the loopers. Something that helps me thread needles (sewing machine, serger, or hand needles) is to lick your index finger. Then swipe it across the back of the needle eye. The moisture helps draw the thread through the eye.
It helps to have the needle at the top of its cycle when threading, Removing the presser foot while threading the needle will sometimes help reduce the interference.. Be sure that your thread is not too big for the needle.
These videos may help:
Janome Threading the overlocker
Janome Domestic Overlocking Machine Tutorial
Don't feel bad. It took me 8 hours to thread my first serger, but my problem was getting the loopers threaded. Practice does make it easier...
Nov 06, 2015 | Sewing Machines
Serger is not stitching
... not quite sure what you mean by "not stitching", here are a few things to check. If the problem is more specific, please leave me a note with more details.
Let's start right from the beginning (for 4-thread overlock/serge):
1. According to the serger manual, ensure that the proper needles are being used. That they are inserted all the way up into their positions and that the flat side of the needle is facing away from you. The left needle will appear to be shorter that the right, that is OK, all is going perfectly.
2. Use four good quality spool of serger thread (good quality sewing thread is fine also) and place them on the spool or cone holders. There should be "little bucket looking things" that fit onto the cone pins to make the cones sit nice and straight, use them. Rattling thread will cause grief.
3. The first thread to be loaded onto the serger is the Upper Looper ...it is the big needle looking thing that swings left to right and back again above the sewing surface. Follow all the threading guided according to your manual, the threading guides are generally coded in a colour specific for this looper. Once the eye of the Upper Looper is threaded, place the thread under the presser foot and to the left. Presser foot down.
4. Next is the Lower Looper, the big needle looking thing that swings left to right and back again under the sewing surface. It can be a bit tricky in some sergers as the thread need to pass to the left and then back to the right under the sewing surface. Your manual should have a good diagram if you can not follow the threading guides on the serger itself. Again the threading guides are generally colour coded with a different colour but specific for the Lower Looper. Once the looper is threaded, it is important that the thread is placed directly OVER the Upper Looper as it comes out of the eye of the Lower Looper. Place the thread now under the presser foot and to the left. Presser foot down.
5. Thread the right needle front to back and place the thread under the presser foot and to the left. Presser foot down.
6 Thread the left needle front to back and place the thread under the presser foot and to the left. Presser foot down.
7. Hold the four thread ends firmly in the left hand and give each thread individually a good pull down over the serger and behind, this will ensure that the threads are all engaged in the tension dials.
8. Set the tensions to the middle number, although this may vary with the brand and model of your serger. If you have the manual check for the correct settings specific to your unit.
9. Set differential to 'normal', or '0' (if your unit has one)
10. Set stitch length to about 2 1/2 to 3.
11. Make sure that the blade is in cutting position. We can trouble shoot blade position later if needed.
12. Make sure that you have the overlocking plate installed ... not the rolled hem plate (if your serger has two plates). Some sergers use the same plate for both functions.
13. Using two layers of medium weight fabric do a test stitch, what is the result? Is a chain forming? Are there stitches on the fabric? Are they looking the way they should?
Hopefully this has helped you, please let me know.
Cheers.
Sep 01, 2014 | Sewing Machines
Singer 756u stitches not catching
So this is a serger? Might have been nice to know that. Make sure you have threaded your serger in the correct order. upper looper, lower looper, needles from right to left.
Make sure you do this with the presser foot lever in the UP position. Make sure all the threads are pulled fully into any tension guides.
Sep 01, 2012 | Singer Sewing Machines
No chain forming on 1034d
You may have re-threaded in the wrong order. The correct order is upper looper, lower looper, right needle, left needle. So 3,4,2,1 (if numbering left to right)
Jul 23, 2012 | Brother 1034D Mechanical Sewing Machine
My Bernina Serger 800DL is not sewing right. I have threaded it twice and it still doesn't work. Can you help me with this problem??
Sometimes you have to remove all the thread and start over.
Make sure:
The needles are inserted properly.
The thread antenna is fully extended.
The loopers are at their highest position.
The presser foot is up.
The tensions are open/zero.
Begin threading from the right to the left.
Good luck - I gave in (and saved the life of my old serger) and bought an air-jet threading serger.
Apr 27, 2010 | Sewing Machines
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
My serger will only sew a few inches, then the thread on the lower looper breaks. I have checked threading, rethreaded many times.
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
Apr 01, 2010 | White Sewing Speedylock 1600 Mechanical...
I dont know how to thread this serger. i dont
Have you opened the front of the serger to see if there is a threading guide.
Basically:
Lift the thread antenna to it's highest position.
Lift the presser foot and set the tensions to zero.
Turn the handwheel so the loopers are at their highest point.
Begin with the upper looper (first thread cone on the right/ end of looper is pointing toward the presser foot). .
Second spool is for the lower looper (end of looper is pointing away from the presser foot).
Third spool, right needle; fourth spool, left needle.
Be careful that the threads do not cross during the threading of the loopers.Follow all the guides, taking the thread under the presser foot and to the left side of the serger.
Set the tensions back to 3 - 6 and lower the presser foot. Sew a few inches and if the threads knit into a chain, you can then do a test sew with fabric.
Simplicity's Simply The Best Sewing Book has good information with regard to using a serger that you may find beneficial.
Feb 24, 2010 | Sewing Machines
My white 2000 serger is dropping the thread on the first needle when I sew with it- the loopers, both upper and lower are working correctly in conjunction with the "right upper" needle. I have changed...
Could be as simple as poor quality thread (not using MaxiLock thread), the needles not inserted properly (the left is slightly higher than the right), a missing stitch forming pin on the needle plate, the needle bar being too high or a looper timing issue.
As the needles raise, the upper looper should move to the right with the right needle tip slightly above the eye of the looper.
Jul 19, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
