Question about AEG Microwave Ovens
Roller iron type 607402028 operating manual - AEG Microwave Ovens
I have a Bosch steam iron TDS25, and the handle of the iron is getting red hot and water is coming out of the back of the iron. Help!!
Steam irons become clogged from water deposits. You may clean your iron with white vinegar and water. You should use distilled water. Make a Mixture of 1/2 water and 1/2 vinegar, and pour the mixture into the iron as you would when you fill the iron with water. Turn the iron on 'steam' and let the mixture run through. You may need to do this a few times, depending on how clogged the iron is. After cleaning use distilled water to fill the iron, becuase distilled water leaves minimul deposits behind.
May 01, 2014 | Microwave Ovens
Panasonic Oven model No NN-C784MF/WF
I would keep the items in. Usually, oil is sprayed on which can cover anything that is in oven at that production step. Won't hurt anything one way or the other.
Mar 12, 2014 | Microwave Ovens
My iron is squirting out brown gunk from the steam holes under the iron itself. i have cleaned and rinsed it out. the manual says it is a gc 7430, gc7420.
Sometimes using vinegar and water will clean out your steam iron - but smells really bad. Usually the brown gunk is a sign that there is corrosion so even if the vinergar works, you should plan on buying a new iron in the near future.
Jun 22, 2011 | Microwave Ovens
I bought the waffle iron at a church thrift shop and there wasn't a manual or recipes
Hello Anyduckfood,
I understand that you purchased a Waffle Iron at a church thrift shop you did not receive the directions or any type of recipes for the unit.
Most waffle irons are set up to cook a waffle in one minute. They take a few minutes to heat up like about 5 and then you may cook with them. You generally use a nonstick spray (pan, etc) then put your batter on the lower griddle and close the upper griddle. The batter will expand to the upper griddle and make the shape of your waffle iron.
Recipes: there are many different places that you can find waffle recipes, here are a few links to recipes
http://allrecipes.com/Recipes/Breakfast-and-Brunch/Waffles/Main.aspx
http://www.waffle-recipe.com/
http://www.mrbreakfast.com/recipe_collection.asp?subcategoryid=5
to find more waffle recipes just type "Waffle Recipes" in a search engine of your choice and you will probable by amazed at how many different recipes there are.
Thank you for choosing FixYa.com
Justin
Mar 31, 2011 | Microwave Ovens
How do I descale a russell hobbs slipstream iraon - I have looked on your site for free user manual and can not find it.
If you talking about descaling the built up calcium deposits in an iron, then there are many commercial products. You can find them in your grocery store, and reading the ingredients you may find mild phosphoric acid which is used in descaling large boilers.
But I prefer to use white vinegar (mild apple acid?) half and half mixture, poured into the iron and let heat for a few minutes and after cooled down dump the mixture out, repeat if necessary. When you refill the iron to use squeeze a little lemon juice in the water to make the iron goods smell lemony instead of vinegary, and the lemon juice is also acidic and will remove some of the scale.
Dec 31, 2010 | Microwave Ovens
Looking for a link to a user manual for a T-FAL 1656 iron.
You can get the manual on the link below. Scroll down to product detail then click on product manual.
http://www.amazon.com/T-Fal-1656-Ultraglide-Iron/dp/B000050AUS
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Microwave Ovens
Sears / kenmore Is there an operating manual on line
Go to managemylife.com and type in your model number under the "Manuals" link. Your owner's and installation manuals should be available in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 23, 2010 | Kenmore 63792 Microwave Oven
I WANT TO GET AN OPERATING MANUAL
You are on the internet so type in the mfg of your unit on your search page. If you find the mfg website go to Support. Most operating manuals are now available from mfg's web sites.
May 05, 2009 | Microwave Ovens
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
83 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
