Question about Bunn Dual TF DBC Coffee Maker
What is an error code on this screen called a "FActory Blow out" Now the machine will not get pass this code.
Bad touch pad! you need to replace the main touch pad!
Posted on Sep 17, 2012
My kyocera km-2550 multifunctional copier has started showing a error message "call for service c6000" and a phone number in asterisks. kindly advice on what to do or if there any online help.
This is fuser unit error code, you can try to reset it might work, but if the erorr code came back then you need to change the fuser unit.
In order to reset this code: follow those steps
on the panel press 1087 1087
The screen will change to service mode
on the panel again press 163
now look at the screen and you will see Excute.
Select Excute and press the Start key.
The Machine will rebot or it will asks you to turn it off and on.
After the machine load again, it should be good, if the Error came back!! Then change the Fuser Unit.
Oct 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Left auger not working. Msg. says "auger fault" then "sensor".
there is a sensor on each side in the back that monitor the speed of the auger to determine thickness of the slush. if the sensor is dusty, it causes an error.
remove the 2 screws and the panel in the back behind the bowl on that side. you will see the motor and the sensor in front of it. use compressed air to blow out any dust. next, check to see if there are 2 pins on the shaft that pass the sensor. if one is gone, you will need to have it replaced.
Jul 29, 2011 | Bunn 340000068 6 Gal Model Black ULTRA2...
Whilst running "pc-doctor" on my
Well, i have no expertise on pcdoctor and can't find that error code, i doubt that it's actually an error, why not try another piece of software to benchmark your video card then you will see if there is in fact an error.
This might be useful (http://www.futuremark.com/benchmarks/3dmark06/download/)
Nik
Jan 28, 2011 | Computers & Internet
Error codes "sud" then also
F35ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked
Jan 05, 2011 | Washing Machines
Hangs up on timer number "19", sometimes shows
Inlet error. Took longer than 10 minutes to fill OR the central computer control thinks it took longer.
themobilian_35.jpgTake the top off and hunt down the small rubber tube from control to tub, blow out the sediment. Do the water level test as shown in the manual and more here
Nov 03, 2010 | LG WM1815CS Front Load Washer
I need a way to restore my factory settings, but n...
Dial *#06# from your phone. A 15 digit code will appear on the screen, which is called the IMEI number of the phone. Pass this number over to me.
May 20, 2010 | Nokia 5310 Cellular Phone
I have a Funai HDR-B2735 dvd/video cassette recorder with HDD. When turning the machine on, it automatically switches off with the screen displaying the message "System error 02/56" before going...
Exact same symptom as above, little flashing "W" on standby, error code 02-56 on switching the unit on, promptly turns itself off. It would help no end if Funai would publish a little bit more info about these error codes on their site, or have a forum somewhere. Gona try a factory reset and a replacement HDD, dont know if i could replace it with a new one or not. any ideas or experience with these errors would be greatly appreciated!
Aug 18, 2008 | Televison & Video
Ricoh Aficio fax 5000L (error code & Factory Settings?)
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
Nov 27, 2007 | Ricoh FAX5000L Plain Paper Laser
Bunn Dual TF DBC Coffee Maker Logo
109 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
