Question about Miele Advanta G2020SC Dishwasher
Have Miele G2020SC and it won't stop draining even after the water is out. Have to unplug to stop from running, won't stop when door opens
  • 3 Answers
Sounds like a bad float switch
Posted on Feb 11, 2011
Miele W1926 Door Won't Open
You probably still have something stuck in the filter in have had the same problem and found it to be the remnants of hair scrunchie.good luck
Feb 22, 2013 | Miele W1926A Front Load Washer
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Jan 04, 2011 | Washing Machines
The door is stuck
Link to the manual...
http://www.miele.co.uk/Resources/OperatingInstructions/W%20320.pdf
Open the flap covering the drain plug on the lower left of the machine (there#s a plastic tool to lever it open stored on the inside of the soap dispenser drawer).
Now the flap is open, you will see a small circular toggle handle. Pull this down, and the lock should pop open.
If you have water in the machine, this will now spill out unless it has already drained. If you need to drain water, place a tray under the circular plug you have uncovered and slowly unscrew it.
Jun 29, 2010 | Miele W320 Front Load Washer
Help ! I own a Miele Touchtronic W1113. I put to0 much Zero liquid soap , using cold water . Now the machine flashes " Fault " for intake and drain . I opened the trap door and let the water drain over...
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
Feb 15, 2010 | Miele Touchtronic W1113 Washing Machine
My g595sc miele dishwasher after about 2-3 minutes of working come to stop with the "WATER INLET" light on. Please help.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Jan 22, 2010 | Dishwashers
Our MIELE TURBOTHERMIC shows a red indicator light on the topic of: drain/watersupply.when switched off and restarted, it evacuates the water succesfully and commences the cycle but then after two minutes,...
Dec 26, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Miele
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Dec 24, 2007 | Miele Touchtronic W1213 Front Load Washer
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher not running
just got this, and have same prob, i have run through all checks
Aug 26, 2006 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
192 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
