Question about Roper RAS8445KQ Top Load Washer
Does not spin fast on high spin - Roper RAS8445KQ Top Load Washer
  • 25 Answers
U MAY NEED TO CHANGE THE CLUTCH AND CHECK THE CENTER POT IT HOLD THE TUBE.I DON'T KNOW U SKILLS ,BUT MAYBE U NEED A TECH TO DO IT.
Posted on Nov 10, 2010
High spin does not work
Hi!!
In order to Spin Dry (FAST), the lid must be closed, If the Lid Switch is not operating, the circuit won't be closed and the machine will not Spin. Try bypassing the switch by connecting together the two wires on it. If the machine Spins FAST, replace the Switch.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 11, 2011 | Kenmore Washing Machines
Washing machine wont spin fast
If the motor has a twin speed check the high speed winding. If the washer has a gear box for high speed , check and see if the high speed is initiated while it is on high speed spin.
Feb 05, 2011 | Washing Machines
Washing machine not spinning fast enough and
Check motor capacitors. Check freeness of the drum rotation, if you suspect clutch
Apr 02, 2010 | Washing Machines
Washer will not go into fast spin cycle
SOUNDS LIKE YOU MAY HAVE TTO REPLACE YOUR BELT ON YOUR WASHER. I AM NOT A MECHANIC, BUT I THINK THIS WILL HELP.
May 13, 2009 | Frigidaire Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Wwsr3090t8ww
It's possible that the high speed windings on the motor no longer work, or it could be the clutch.
If the motor is spinning very fast, but the tub is not spinning, then the clutch is broken. If the motor is not spinning fast, then it probably needs a new motor.
Sep 06, 2008 | GE Washing Machines
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
No high spin
Make sure you are set for normal cycle. Some permanent press cycles only spin on low. Also check that your drain hose is not kinked. If it is the water may not be draining fast enough.
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAS8445KQ Top Load Washer Logo
22 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
