Question about Smeg SUK61MFX Gas Kitchen Range
I want to buy a SMEG SUK 61 MFX gas cooker with an electric oven. Would I be making the correct choice?
  • 1462 Answers
SOURCE: Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
Posted on Mar 31, 2007
  • 209 Answers
SOURCE: smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Posted on Sep 09, 2007
SOURCE: Smeg Oven electric burning smell
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Posted on Apr 01, 2008
SOURCE: Smeg Oven blowing
Phew! I'm very grateful for all that freetek but it certainly sounds like I may have a problem outside of my ability. I guess I will have to bite the bullet and get some expensive engineer to come in and sort it.
As a layman I just can't understand how it works fine for 5 years and without any alterations made simply stops! :-(
Thanks for all the advice, I will post back when and if I solve the problem, or wether in simply ends on the dump!!!
Posted on Oct 16, 2008
SOURCE: how do i change the volume on the oven timer? i
whilst alarm is ringing press the minus (-) button. there are 3 volumes to choose.
Posted on Feb 11, 2011
Not heating up beeps continuously
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
http://how-2-repair.com/buy-paul-a-beer/ Paul is from the Naturally he would appreciate beer How to Repair Home...
May 23, 2012 | Smeg S1100MFX5 Electric Single Oven
How do i change the volume on the oven timer? i
Jun 06, 2010 | Smeg Kitchen Ranges
Smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Nov 18, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Replacing fan element in Smeg SUK61MFX
what colour cables go to the 2 conectors on the fan element of a smeg suk61 mfx cooker
Feb 16, 2008 | Smeg SUK61MFX Gas Kitchen Range
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Open Questions:
Smeg SUK61MFX Gas Kitchen Range Logo
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
