Question about Cadco OV-250 Electric Single Oven
My cadco ov-350 mod-xa006 works fine but now she takes 20 minutes to start, the fan i mean . would love to fix this problem , i am using this oven for commercial use and tried to purchase another oven and customers complain about the quality of the bisquits. appreciate your time Tami
3 Suggested Answers
SOURCE: cadco unox Mod XAF193
You can order the XC605 "air reduction kit" from the manufacturer catalogue.
Posted on Nov 14, 2008
  • 193 Answers
SOURCE: I need to replace the
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
The fan is blowing but the oven is not getting hot
It is either the thermal fuse or the relay I have the same problem- now I am trying to figure out how to install the new parts-I have both because the whole oven has to come out to fix it
Aug 14, 2012 | Cadco Ov-023 Oven
Oven door seems sprung as if a spring may be shot and door dose not close all the way?
You need to replace both oven door hinges, as the springs are weak, and there is no adjustment available.
Sep 25, 2010 | Cadco OV-400 Electric Single Oven
Oven touches cabinet inner wall of cabinet. Fire hazard or not?
The rear of the oven has approx 3" or better insulation you are ok
Jan 17, 2009 | Cadco OV-250 Electric Single Oven
Cadco unox Mod XAF193
Oct 16, 2008 | Cadco Ovens
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
Grinding noise every now and then
If this is a self-cleaning model it is possible that the movement of the mechanical parts are at fault. Toward the back you should be able to find the motor and drive rod. Check these first and yes, there could be a loose or faulty fan motor.
How long is the sound there ?
Jan 22, 2008 | Cadco OV-400 Electric Single Oven
Want to remove broiler unit
slide on connectors would be the most likely, however occasionally you may find screw terminals or soldered joints - see if you can post us a photo and we could hopefully be sure you could also merely cut the wires next to the connectors, making sure the bare ends are properly insulated in case someone turns the broiler on at a later date by accident. Hope this helps - post back with a photo if you can :)
Mar 24, 2007 | Cadco OV-350 Electric Single Oven
Blowing circuit breaker
If you live in Rancho Cordova, CA and need appliance repair service call us at 916 823 3070 or visit our website Rancho Cordova Appliance Repair 916 823 3070 Rancho Cordova CA
Sep 02, 2017 | Cadco OV-250 Electric Single Oven
Cadco OV-250 Electric Single Oven Logo
172 people viewed this question
Top Cadco Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Cadco Oven Expert? Answer questions, earn points and help others
