Question about Garden
I have a Power Devil Cross Pull Mitre Saw, I believe the number is PDW5047CPM. I need to change the blade but I have lost the instruction manual. Can you help???
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
SOURCE: Changing the blade on a power mitre saw
http://www.superiorairco.com/cgi-bin/workshop.pl
Posted on Jul 20, 2010
jyackle5
  • 8197 Answers
SOURCE: I am unable to put
May I get the maker of the saw that you need the manual for so I can help you more
Posted on Feb 19, 2011
jyackle5
  • 8197 Answers
SOURCE: I need the bolt that
To get the bolt that holds on the blade please go to the link below and send mastercraft/altocraft and email.
http://www.mastercraft.net/
Posted on Feb 28, 2011
  • 81 Answers
SOURCE: how do unlock mitre saw
There is a lever or push button by the hinge (where the saw pivots).Just push down on the top of the saw and release latch.To lock back down , just push down on the saw and put lever back in the lock position.
Posted on Jun 04, 2011
Tooltec 1800w mitre saw all I did was change the blade and now the saw is dead
Does the motor hum when you pull the trigger? If so, check that the push tab for securing the shaft from turning while changing the blade is pulled out all the way. Sometimes fine saw dust can get inside and prevent the spring from pushing the tab back out all the way. If there is no hum, check the power source.
Mar 23, 2017 | Blade Saws
I have a Performance Power Tools PP1100MS mitre saw and i need to replace the blade but its not obvious how to do it and i have no manual.
Hi, I too have a performance power mitre saw pp1100ms and need to replace the brushes. I have the parts but no diagram...any advice please ????
Nov 10, 2013 | Saws
I bought a second hand Power Devil Mitre Saw PDW 5013. It has no instruction manual and I need one.On starting up the saw, the blade spun but sounded terrible, loud and not right. On trying again, several...
Try the blade first. It should be tight and have no real wobble to it. Although my first guess would be the brushes, These are generally accessible from the outside. There is often a number or something to identify the brush so that you can get a proper replacement pair. If the motor starts right away and the blade does not then the blade is loose. re- reading your post it could well be the blade. Often these are reverse threaded, so you tun them clockwise to get it off. You may well want a new blade anyway, and there are different types for different jobs. Watch your fingers and unplug the saw when messing with the blade- it is easy to hit the switch when undoing the blade.
Jun 10, 2011 | Saws
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Oct 23, 2009 | Saws
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
I have a 10"DELTA Miter Saw and need to change blade. Please describe how to remove and replace blade. Thanks
Without a model number I cant look for this saw, but if it is like the other mitre saws that I work on, the lower guard should have a bolt holding it in place, loosen the bolt so you can move the guard and the blade bolt is usually LH thread, on the backside of the gearcase by the blade there should be a spindle lock, rotate blade until it locks and then remove bolt. If your saw is different please give me the model number and I will pull up a schematic and look at it.
Jan 16, 2009 | Saws
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
