Question about iRiver H320 MP3 Player
H320 20 GB MP3 Player will only charge when connected by USB cable to PC
Recently replaced battery, and obtained a new charger with correct specifications. I believe the fault will be due to some sort of internally poor connection. Can anyone help me as to how to go about fixing this problem? Thanks.
  • thephinester Jun 17, 2008
    unfortunately i dont have such a process available on my pc. is windows XP if that changes anything. thank you anyway
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Follow this process
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
Posted on Jun 17, 2008
Can you keep player plugged into usb charger while playing music files indefinatly or will it over charge and possibly cause damage? im shopping around and am not even shure it will play while pluged in to...
You can keep the Sansa plugged in without fear of overcharging. The Sansa will play while it is connected to a USB port that is supplying only power, such as a USB charger operating off a car cigarette lighter. It will not play while connected to a computer.
Mar 09, 2011 | SanDisk Sansa Clip MP3 Player
Can u please tell me how to charge my mp3 player Laser 2G ? its new and they told me that it will be charged when i put it in my computer but i tried and i could not even while my computer is charging .
The MP3 player is charged using the supplied USB cable. When you connect the USB cable into the computer's USB port when the computer is switched on.
If the MP3 player still does not charge, try connecting it to a different computer. If it still does not charge then the USB cable may be faulty.
I suggest you take the MP3 player back to the supplier for a replacement. You should get them to test the MP3 charging.
Jan 09, 2011 | Laser MVP-2G (2 GB) MP3 Player
How do i charge it
Refer to page 12 of your User Manual.
http://download.p4c.philips.com/files/s/sa3346_37/sa3346_37_dfu_aen.pdf
Connect to your PC with the supplied USB cable and it will charge via the PC USB port.
Dec 29, 2010 | Philips GoGear Flash MP3 Player
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
USB Port 2.0
USB Port location
Battery
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
Battery is low on DSUDS Sandisk. I lost the directions how do I charge it?
Does your MP3 has a usb cable cord? Just connect it to your MP3 player and connect it to your pc to charge the battery.
Nov 07, 2010 | iLO (2 GB) MP3 Player
How do i charge it
Three way to Charge you Battery...
1. Charge with USB Cable- Use usb cable and directly connect to you mp3 player, And another attach to the computer.
2. Charge with Charger - directly connect to AC power supply and another attach to mp3 player.
3. Directly Boost - Another way to charge, open your mp3 player and charge your mp3 battery directly (+/-) point with Zapper (zap gun) - It will boost your battery immidietly.
Jan 28, 2010 | Audio Players & Recorders
Creative Zen Vision M won't charge it's battery.
check your usb cable...i had the same problem...
I have a usb cable that came with it ( or some other mp3 player i bought), but it is way too short, so i bought a cheap ($1) and longer usb cable. The computer recognizes the mp3 when connected, but it wont charge with the long and cheap cable.
Maybe you also have a long (or short) cheap usb cable...or maybe your usb cable is plain broke...
Feb 11, 2009 | Creative Labs ZEN Vision:M Digital Media...
Ilo mp3 player won't turn on
Ok, SOME MP3/4 Players indeed charge from the USB port, albeit slowly... usually tho there comes a charger that plugs into the "Mains" and then plugs into the USB socket on the Player.. Sometimes if the Battery goes really "Flat" the USB port is unable to supplu enough "Current" sucessfully charge it up. (Hence the need for wall charger) IF it was entirely Via USB it would take many hours, I would at least think overnite. Hope that hepls.
Jul 30, 2007 | iLO (2 GB) MP3 Player
iRiver H320 MP3 Player Logo
49 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
