Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Why does my washing machine make a clacking noise during agitation...it goes clack, clack,
  • Whirlpool Master
  • 1,902 Answers
Hi
Clacking noise comes when either the agitator or the transmission or clutch assembly goes bad. To check which part# has gone bad you'll have to open the unit and first check the agitator. Please get back to me if you have any other questions.
Kevin
Posted on Nov 10, 2010
Washer started to smoke during spin cycle then a cracking noise began after that.
You may just have a defective drive belt. The motor itself will smoke under certain failing circumstances. Can you give me a model # ?
Jan 07, 2013 | Washing Machines
General Electric Washer Model# whre5550h1ww makes a clacking sound in wash cycle about i se
There is a known problem with this GE model. Remove the front panel, look at the base plate below the motor. Can you see that it has been rubbing there? On that model the "front apron bracket" fails allowing the motor to rub againist the base. You will need to replace the apron with the new design they have out.Here is the part to order.
You may also check this by removing the front and run a load of wash and watch the motor.
Please post back your finding to me.
Nov 02, 2012 | General Electric WHRE5550H Top Load Washer
The spin cycle does not work
most likely during the spin cycle it make (or used to) a clacking noise?
if so the motor coupling is cracked
Jul 18, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
When i give it gas it makes a clacking noise but when i put super premium gas it helps the noise a little bit
check the motor mounts they might be weak causing a weird clacking noise that goes and comes
Feb 04, 2010 | 2003 Jeep Liberty
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
2002 yukon clack clack noise due to ac/ ac belt/ tensioner
have the ac recharged and pressure tested
May 27, 2009 | 2001 GMC Yukon
Loud while agitating
CHECK COUP-LER BETWEEN MOTOR AND GEARBOX.if coupler good,then gearbox bad.
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
"Clacking sound when receiving faxes"
a clacking noise is not good, what's the make and model of your machine.
Thank You,
Mikey
Apr 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Slow cycle making a loud CLACKING noise???
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Apr 08, 2007 | Kenmore 45981 Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
500 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
