Question about Canon PIXMA iP4000 InkJet Photo Printer
I want to change the size of the printed letters, how can U do that? Can I do this with the printer or do I have to chanhe something on my PC
  • 340 Answers
You will need to change the font size in the program in which you are trying to print from. If it is in Word or something similar go to the top and you will see font size, change it to the desired size. If it is from a web page that you are trying to print from you will need to go into your internet page and you will see the choices at the top that say page, safety, tools... etc. Click on Page and go down to text size and change the size of your text here. You can always change it back by reversing the steps above.
Posted on Nov 10, 2010
How to solve the pc load letter in konica Minolta Printers & copiers?
Is this what it's reporting on its display panel when you try to print? Most likely the paper stop in the drawer has moved or been changed to something other than letter; so the printer thinks it has something other than letter size loaded (probably got moved to A5) The printer "reads" the the drawer stops, it does not "see" the paper it needs.
Oct 04, 2013 | Konica Minolta Office Equipment & Supplies
If envelope printing Canon PC-D340 All-In-One Laser Printer incorrect paper size problems.showing
You need to make sure the paper size and that of the printer matches in the dialogue box.
i.e assuming you a printing an envelop DL size, make sure your envelop is the exact size you choose in your page layout.
secondly, open the properties in the printer dialogue box, where you have letter, change the default "letter" paper to you envelop size.
Note: if your envelop size is not accurate and the actually printed, you will still receive "incorrect paper size" error. At this point I turn of mine and turn on again.
Jul 17, 2011 | Canon PC-D340 All-In-One Laser Printer
How do I change from Letter size to legal size? I
try under printer driver properties, under custom size, select lgl ( legal ) or by inches.
Aug 07, 2010 | Canon imageCLASS D320 Digital Copier
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
I dont get prints when I give print command but when I use the
What does it say in the display?..load paper plain letter....load MP feeder? I think the problem is the following. On the menu right arrow over to the paper menu. Hit select...it then gives you sub menus...paper type...paper size. Go to paper size...specify the tray your using...most likely tray one. Hit select and see what size paper its set on. I'm assuming your trying to print on letter size. If it says something else like legal...executive..A4...change it in the menu to letter. If it changes to letter hit select to save the setting. Now if it won't change in the menu pull open the paper tray. The back paper guide is real sensitive on these machines. You have to make sure the geen/blue tab on the back is set exactly into the letter size slot on the tray. That slot will be slightly bigger than the rest of the teeth you see on the bottom of the tray. If you have it set right then there should only be the 2 bottom tabs extending on the outside left side of the tray. Those tell the printer what size paper is in the tray. If theres 3 sticking out...you still don't have it set right for letter size. Okay..the last thing. Something that goes bad on those machines is the tray card. Its where those 2 tabs on the side of the machine I mentioned interface with the printer. They can go bad. You can either replace that card..or trick it. To trick it go back to the paper menu...paper size tray 1. Open the tray...and close it again. The setting on the screen will change to another size...do that again or until it changes to letter size. The leave it alone. You may have to do that everytime you add paper an reinsert the draw unless you replace that card. Hope this helps!
Mar 24, 2009 | Lexmark Optra S 1855 Laser Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Canon PIXMA iP4000 InkJet Photo Printer Logo
104 people viewed this question
old marine
old marine
