Question about Miele Coffee System
We have a Miele conffee machine. Tried to run the descaling program and now something has gone wrong. There is just a line through the main screen and none of the buttons do anything. Turn on/off at the mains and you get the time/lighting options as normal, but when you press the power this line appears and nothing works. Can anyone help? And what are the options in terms of getting an engineer out?
    Problem Solver:
  • 12 Answers
What's the model # ? If it's a CVA615 or CVA610, did you complete the descaling process properly, by performing the final rinse, (re-filling water tank and turning the steam selector on?)
Posted on Nov 17, 2010
Miele CVA615 won't descale. Program mode just says descale but won't perform process. I have followed all the instructions.
hmm,,,is there water in the water tank? U need to put water there manually, while descaling. have you tried to switch the machine off and on again? My Miele descales 2 times in a row every time... not sure why. if it won't start descaling process itself, then choose descale from the maintenance list. I really don't know, what else to suggest. Best wishes!
May 31, 2014 | Miele CVA2660 Stainless Steel Coffee Maker
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
I have the miele espresso machine wall unit. It counted down number of coffees until it would descale and now nothing. What do I need to do to descale?
http://www.miele.co.uk/customer/OperatingInstructions.aspx
Hi you need to run a descaling program. Which is basically putting descaling tablet in water supply(tank) and running program. See link above to selected correct model instruction book.
May 30, 2010 | Miele CVA615 Espresso Machine
No program mode in Miele CVA620 espresso machine
my miele cva 620 coffee machine not working only the LED screen lit up and nothing else? any ideas.
Apr 10, 2009 | Miele CVA2650 Stainless Steel Espresso...
Descale red light, wont go off, and can i use any delcale tabs
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Mar 12, 2009 | Bosch Coffee Makers & Espresso Machines
Descaling problem
make sure the * is on the descaling line
Jan 25, 2009 | Miele CVA615 Espresso Machine
Descaling, not reading program mode
turn to lock and hold ^ button for 10 sec to change security setting on or off. should be off . then switch to program mode and use up & down arrows to descale with * , hit enter turn on steam.
Jan 01, 2009 | Miele CVA615 Espresso Machine
Miele Coffee Machine
For the first you can change language via menues on the machine. second the machine must be descaled. There is possibility to by descaling tablets. Must be the one to the machine. Usermanual is available at miele.com
Best regards happy Miele owner
Dec 10, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Miele Coffee System Logo
249 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
