Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
    President:
  • Psi Master
  • 1,383 Answers
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Posted on Nov 10, 2010
  • Travis Biggar May 08, 2013
    This is the correct pump diagram. I still have the original manual for the pressure washer, however, it's useless for locating replacement parts. Seriously, it lists parts as "screew", "safty valve", "big oil seal", and my favorite, "bearing lamella" (bearing disk).
Engine stalls when not using wand
Frank, either the unloader valve is out of adjustment(try loosening it off) or it is faulty and needs rebuilt or replaced as most people do.
Check the attached vids,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 15, 2016 | Honda Black Max 2600 PSI Pressure Washer
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
I am looking for a replacement hose for my Blue Max pw2200/03435. Does one exist? If so, where can I get one?
Here is a site that shows the lightweight blue max power washer hose
http://www.shopping.com/Psi-Blue-Max-2200-Psi-High-Pressure-Gas-Power-Washer/products
It looks to be a right-fine chinese product manufactured using the technology we paid-for and developed over the past 50 years and then gave away with our jobs overseas.
If you bump up to professional power washers..
Power washer hoses are interchangeable as long as the quick-connects on end of hose can unscrew.
We used power washers a couple times a week. When I needed a new hose, I went to the hydraulic hose shop. They make steel-wound hydraulic hoses for tractors and heavy equipment.
Search 'hydraulic hose in Your-town-your-state'
If the quick-connect ends of the Blue max hose do not come off, check the quick-connect end attached to machine. If it comes off, you can buy a new gun and hose. If the quick connect on the blue max machine does not come off, then the life of your machine is directly related to the life of that single quick-connect fitting.
Search 'power washer guns'
Here's a site with guns like we used
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 15, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Can i hook up a longer hose to the handle? jim
Hi Jim,
As long as the seals on either end register and screw in tight, the only thing that diminishes the pressure at the wand is the weight of the water within the hose if it was pushing upwards against gravity. That would be a seriously long hose.
So yes, you can hook up a longer hose and expect the device to function in the same manner with out any ill effects.
Best regards
Mike
Jun 07, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
I bought a new Blue Max Gasoline pressure washer and when I started it up I have very little water pressure. Are there any comprehensive instructions manuals then what were supplied with unit? Thanks Ron
You can download the manual here: http://www.farmprotractors.com/hdcmanuals/PW2200-03435.pdf
It is probably the same manual that came with the unit.
As far as pressure... hook up the water supply hose and turn on the water supply. Let the supply hose purge all of the air out. Then turn off the water and connect the high pressure hose. After that turn the water supply on again with the engine off and squeeze the wand trigger. Make sure all of the air is out of the high pressure hose. Then start the unit...
Once the engine has stabilized rapidly squeeze and let go of the wand trigger several times. Your exersizing the bypass / unloader valve spring. By this time you should have good pressure. If you have owned the unit less than 90 days and your sure you have a warranty issue use this link to contact the company:
http://www.homier.com/contacts
Contact Information:
Homier Distributing Company, Inc.
84 Commercial Road
Huntington, Indiana 46750
Hours of Operation:
M-F 8:00am - 5:00pm EST
I note they do NOT include a phone number on their contact page but do state empatically that warranty contact should be made via email feedback@homier.com
You will also need a warranty form here:
http://www.homier.com/return-authorization-form.pdf
Some of these units have a sliding assy on the wand that slides toward the ouput nozzle for adding soap / chemicals. If the slide is not pulled back toward trhe wand and locked into place you will not have any pressure either.
It appears from reading the manual that this particular unhit had 2 different nozzles. One for chemicals and one for high pressure. Plese make sure you have the high pressure nozzle installed. The BLACK nozzle is for chemical use. (page 5 of manual link above)
The red, yellow or white nozzles are all for high pressure with different spray patterns.
This is about the best I can do for you Ron. Hope it was helpful.
Kelly
May 20, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Need parts for Wand
yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Feb 02, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
387 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
