Question about Royal VF1000MX Shredder
My shreader does not turn off automatically - Royal VF1000MX Shredder
    Genius:
  • 1,218 Answers
Have you tried cleaning the "eyes" where the paper is inserted. If that doesnt work you may have defective pcb...contact Royal at 1-800-524-0799 for parts assistance.
Posted on Nov 10, 2010
Have a Staples Model SPL-727MM paper shreader that won't work. Probably jammed, but unable to open it. Found some screw holes in where the tray pulls out, but regilar screwdriver won't fit, too long. Does...
Some home office shredders have the shredding mechanism "permanently" attached with only the bin (tray?) removable. The entire machine has to be inverted to gain access for cleaning. Periodic cleaning is necessary maintenance as shredders of this type are not self-cleaning.
May 17, 2014 | Office Equipment & Supplies
Why wont my 1989 acura legend start, it cranks up but it wont start?
Probably your fuel pump. If its EFI remove the cap from the shreader valve on the fuel rail and turn the key to the on position. Listen to see if you can hear the fuel pump kick on. Leave the key on and press the shreader vlave. if fuel doesn't come out hard and strong then either it's the pump (most likely) or the fuel pump relay might be bad. That relay can be changed with other relays of the same part number in the fuse console under the hood. Try switching it out and see if the car starts. If all that checks out good then the next step I would take is to look at the cam / crank sensor.
Jan 19, 2013 | 1989 Acura Legend
Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
Jun 06, 2010 | Troy-Bilt ChipperShredder
PS60C-2 Shredder: Fellowes P50CM paper shreader motor runs but cutte...
One of the drive gears has stripped its teeth, usually caused by overloading the machine. These are personal shredders and parts are not available in my experience.Sorry.
May 03, 2010 | Fellowes Office Equipment & Supplies
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Apr 04, 2009 | Fellowes Office Equipment & Supplies
Blade gone south (shreader)
www.gopresto.com you can order parts here!
Please rate this FREE response!
Dec 07, 2008 | Presto SaladShooter Plus Food Processor
The shredder runs perfectley in the reverse direction, but does not run at all in the shredding direction
I have seen many shreaders that are caked with paper underneath the blades.
After you remove the power, turn the shreader upside down (if possible )and completely clean the area.
Make sure you use shreader oil after you clean it
Dec 01, 2008 | Office Equipment & Supplies
FELLOWS PS 65C SHREADER
There is probably astripped or broken gear inside the gear box.
Nov 05, 2008 | Fellowes Office Equipment & Supplies
Shreader Malfunction
If the gears are stripped it will cost more to buy them and pay for the shipping if it is not under warranty. You also have to think if the gears are stripped what caused this to happen. It probably put a lot of stree on the motor also. So you may not have a loy of time left on your motor. I hope this will help you.
Sep 26, 2008 | Office Depot Ativa DQ60M Shredder
Royal VF1000MX Shredder Logo
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
