Question about Keurig B70 Coffee Maker
It drew the water out of the reservoir, then it began to brew. Only a splash of coffee came out. It said it was brewing, but nothing was happened. Subsequent attempts only produced a splash of coffee each time.
  • 2,069 Answers
This is a common problem and as has been noted before, I'm going to give links to two possible solutions that have before been posted on this FIXYA site to avoid repeating the same. LINK1 and if this doesn't solve your issue, then LINK2
please inform me if you think of my suggestions differently.
Posted on Nov 15, 2010
Keurig troubleshooting
had the same issue as you do, unplug the unit. I let it sit unplugged for about a minute and then plugged it back in. Suddenly, it appeared to be functioning normally again. The screen indicated the full range of brewing size selections and when I selected my size and hit the brew button, it actually drew water from the reservoir, then it brewed a nice hot cup of water. It's been working fine ever since
Aug 13, 2014 | Keurig Elite B40 Coffee Maker
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
We have just descaled our Platinum unit and reset all the functions. When attempting to make a cup of coffee, it says it is brewing, but NOTHING is happening. What do we do?
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this helpful tip
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Platinum B70 Coffee Maker
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Apr 26, 2010 | Bunn 12 Cup Coffee Brewers with 3 Lower...
Coffee spilling out the sides of the carafe
I had a Mr Coffee that did that. It was running across the brew pause arm and making a mess. I discovered that the position of the carafe had a lot to do with it. If I brewed with the handle pointing out towards me, very little leaked out. I finally tore the brew pause arm off of the bottom of the brew basket. I works great and hey, I can wait ten minutes for a cup of coffee! However, if yours is new and doing this, I would contact the company and see if they'll make it good.
Jan 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Coffee maker not working
Here are some of the most common problems that can cause your drip coffee maker to stop working:
  • The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker -- replacing it improperly can lead to a fire.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
There are two problems that are nearly impossible to fix:
Failure of one of the heat-sensitive switches
(This is The coffee maker's temperature sensors)
Failure of the heating coil:
(This is the The coffee maker heating coil)
Because it's nearly impossible to get replacement parts, you probably have to buy a new coffee maker if one of these problems disables your machine. Now, when you make coffee tomorrow morning, you can do so with a new appreciation for exactly what's happening inside.
Goodluck,
Please don't forget to rate the solution
Apr 01, 2008 | Keurig B50 Coffee Maker
Continually running/heating
Coffeemakers have two heating elements: a brew element and a keep-warm element. When the water reservoir has run empty, a thermostat switches power from the brew element to the keep-warm element.
The keep-warm element will cause the thermostat to stay in this condition until more water is added [or power is cut off] which will cool it down to switch back.
However, if the keep-warm element has quit working, the thermostat may be reactivating the brew element. With no water in the reservoir, the brew element will heat up till the thermostat trips again, then cool down, etc. This cycle will repeat until power is switched off.
Mar 31, 2008 | Keurig B50 Coffee Maker
Keurig B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
