Question about HTC HD2 Smartphone
Touchscreen failure - HTC HD2 Smartphone
    Problem Solver:
  • 14 Answers
Please,check this for a possible solution.
Posted on Nov 10, 2010
Bizhub 7145
IF AFTER THIS PROCEDURE THE CODE COMES BACK DO NOT RESET AGAIN OR THE FUSER MAY CATCH ON FIRE RUINING A PERFECTLY GOOD DAY HAVE A TECH COME OUT
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Feb 07, 2014 | Konica Minolta Office Equipment & Supplies
7040 manual
if the cod come back after this procedure then DO NOT RESET AGAIN Because the the machine can catch on fire ruining a perfectly good day.
Feb 06, 2014 | Konica Minolta Office Equipment & Supplies
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
My touchscreen is no more working
This is most likely a hardware failure. Phones are typically designed to be extremely hard to fix; you may be able to find a new touchscreen online, but it will likely require knowledge of soldering to correct, and you may end up getting it replaced only to discover that it's the circuit board which has the error.
Nov 04, 2013 | Dell Aero Android Smartphone
Screen Frozen Garmin Nuvi 650 NA
This is a common problem, caused by a touchscreen failure. I have personally replaced well over a thousand Nuvi 6xx touchscreens. More info about this problem can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Oct 07, 2012 | Garmin Nuvi 660 GPS Receiver
My nuvi 650 screen won't work can u help me
This is a common problem, caused by a touchscreen failure. You can try to recalibrate the screen. If this doesn't work, then the touchscreen will need to be replaced. The recalibration prodedure can be found here:
- Jim
Jan 22, 2011 | Garmin Nuvi 660 GPS Receiver
My Nuvi 650 touch screen stopped working. Also my computer will not recognise the device. Doesn't show as a drive. I updated the software yesterday.
If you have a PIN assigned, you must enter the PIN before the GPS will get to the routine where it will communicate with the PC. Of course if the touchscreen has failed, you will not be able to enter the PIN.
Touchscreen failure is a common problem. Please see this link for more information:
- Jim
Oct 28, 2010 | Garmin Nuvi 660 GPS Receiver
Iphone keypad not working
First try a hard reset. Hold down the power and home button simultaneously for 10 seconds until the iPhone reboots.
If that doesn't work you need a new digitizer. If it's a 3G I would advise replacing the digitizer. If it's a 2G I would not advise replacing the digitizer b/c you would have to replace the LCD, Digitizer, and the Glass Panel and the cost would exceed $100.
You could also consider selling your iPhone AS IS for parts or repair on eBay, Craigslist, BuyMyTronics.com or I could make you an offer.
Hope this helps, Rate me please!
Jun 17, 2009 | Apple iPhone Smartphone
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
HTC HD2 Smartphone Logo
77 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
