Sata connection for my dvd drive
My dvd drive is not recognised but it opens and closes, the connections are fine and its the first time the sata slots have been used. pealse help me my dvd drive is liteon 20x dvd writer
  • 1,314 Answers
Check your BIOS and make sure your SATA is enabled. Also verify that the SATA cable is tight in the back of your drive and on the motherboard itself.
Posted on Jun 17, 2008
My dell 170L with IDE h/drive & cd rom wont recognise a sata dvd rom ( connected to sata port & power)
Check that jumper settings are done correctly, also check how devices are shown in BIOS.
Sep 14, 2012 | Dell Dimension XPS 400 PC Desktop
How can I flash my xbox 360? it wont recognize the new dvd rom drive.
Disconnect all cables from the Xbox 360 and remove the faceplate from the front of the console. Lift the plastic tabs on the outer shell and remove the plastic casing from the machine. Unscrew the Torx size 7 screws and lift open the metal cover. Unplug both the power and SATA cables from the rear of the DVD drive and lift it out of the console. Replace it with the new DVD drive, and connect the power cable to the unit. Connect your SATA cable to the DVD drive and a free SATA port on your computer.Turn on your computer and open a web browser. Download JungleFlasher and run the program. As of September 2010, JungleFlasher is the most stable and up-to-date flashing program for Xbox 360, and it is also the only program capable of flashing Xbox 360 drives from within Windows (earlier programs used MS-DOS). Click "Flash .BIN to DVD" in the program's main menu and select your Xbox 360's DVD drive. The program will flash the new DVD drive for use with your Xbox 360 console.Turn off the computer once the flashing process is complete and disconnect your SATA cable from the DVD drive and your PC. Reconnect the Xbox 360 SATA cable to the new DVD drive, then close the metal cover on the console. Rescrew the Torx size 7 screws and replace the outer plastic shell on the Xbox 360. Return the faceplate to its original position then reconnect all external cables and accessories to the console. Power on the Xbox 360 and the replacement DVD drive will function normally.
Feb 27, 2011 | Video Game Consoles & Games
My external hard drive is not recognised by any computer now and I can't access the data on it.
It could be a problem of driver . Try this site :
If nothing really succeeds , the last but drastic solution is to open the box and connect the drive right inside your pc ( provided it's a desktop ) to the motherboard via ide or sata connection . Windows should then recognize the drive .
Regards .
Jan 04, 2011 | Freecom Classic (22095) (22095)...
DVD drive is not recognised. There is power to the drive but no drive letter in My Computer and no discs will play.
The data connection to the motherboard is not plugged in, it's loose or it is not set to slave or master.
You need to open the PC and see if it is connected. If it has a SATA connection, make sure the SATA cable it's plugged into the DVD drive and into the motherboard. If it is a IDE cable, then make sure it is properly plugged into the DVD drive and motherboard. If it is plugged in, make sure the jumper is set to cable select.
Dec 22, 2010 | Dell Dimension 9100 PC Desktop
I have no idea what I am doing. I put in a sata driver on my ide motherboard. I bought and hooked up all cords to connect it and now it only opens and closes. It will not install or read any disc. What...
Thank you for your question.
The fact that it opens and closes means you are very close in getting it to work correctly.
Could we take a moment to sort out the technical aspects of what you are asking/saying?
Sata Driver on IDE Motherboard?
A driver is software that is installed to the Operating System. Do you mean a SATA Converter, so that the IDE connection is changed into a SATA connection? If so, let's move on.
The cords that you connected, is it two (usually)red cords with single black ends at each end? If so, let's move on.
If we have got this far, you will have to enter the BIOS settings to ensure that the motherboard has found your new DVD. If you have your manual it will explain which button to push on initial bootup to enter BIOS. It can be "delete", "F2 or F12', manufacturers are not consistent on this. Once in BIOS you need to make sure all options for the IDE drives are on "auto", makes the BIOS do the work for you.
You do not have to install the DVD, the BIOS recognises the new Drive as a Storage Device like a Hard Drive, no drivers needed.
Although the other thing after successfully getting the drive to read discs is you will need to install the optional programmes such as Power DVD for watching movies and Nero for burning DVD?CD's.
Kind regards
Jun 01, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
DVD wont recognise disc
If your DVD drive don't show up in device manager and if there's no yellow exclamation mark in device manager, try to check IDE or SATA cable connection from your DVD drive to the motherboard. Also check the cable itself (are the wires inside broken?)
Feb 01, 2010 | LG GSA 4163B DVD±RW Dual Layer Burner
How do i hookup sata dvd drive
You should have been supplied a SATA cable if you have bought a new DVD drive. On your motherboard you will see 2 orange connectors just underneath where the older IDE grey cables plug in. Thesae are you 2 SATA connectors. They will be labeled as 0 and 1, if you are not using of these at moment connect to SATA 1 incase you decide to hook up a SATA HDD drive at some stage. Power cable just plugs in as usual. If PC doesnt recognise the drive you will need to go into the bios ( press DEL or F2 at startup) and it will be listed under something like drive configuration and just enable SATA there.
Jan 20, 2010 | MSI 661FM2-LSR Motherboard
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
