Question about HP LaserJet P4015N Printer
My HP LaserJet P4015n is making a high pitched noise when I print. It is also printing very slowly.
    Problem Solver:
  • 5 Answers
Same thing happened to mine at work. All because the paper tray indicator was not exactly on 'letter' size.
Remove the lower tray and remove all of the paper. Insure that the 2 paper size selectors are exactly on the marks for the size of paper you are using.
My HP4015N is now running at full speed with NO ANNOYING HUM!!
Posted on Jan 03, 2011
Hp p4015x that is making a loud high pitch squeal
toner cartridge or fuser or laser/scanner assy
Feb 24, 2015 | HP LaserJet P4015N Printer
HP Laserjet P4015n error 49.4CO2
This is a communication error. Try turning the printer off for 30 seconds and then turning it back on. If not try deleting the current print job. It may be a "corrupt" document. Then try to print a different document. Good luck !
Aug 04, 2014 | HP LaserJet P4015N Printer
My hp laser jet p4015n is printing light, you cannot even read what is on the paper. it's almost like it didn't print at all.
What is the toner level on the printer. If this is a brand new cartridge, it is possible that you have received a bad cartridge.
Feb 28, 2011 | HP LaserJet P4015N Printer
Hp laser jet all leds on and not working
The surge protector or UPS may not be allowing sufficient voltage through to the printer. HP printers do not have built in speakers of any kind. Because of this, they are not capable of making any beeping or squealing sounds. If any noises such as these are heard then the printer is probably connected to an Uninterruptible Power Supply (UPS) or a backup battery. To verify that the UPS is the source of the noise, plug the printer directly into a wall outlet bypassing the UPS.
The following are common symptoms:
  • High pitched squealing, beeping sounds, or alarms (UPS)
    NOTE: Noise over the phone line can also cause high-pitched squeals and beeping sounds.
  • Inexplicable or false error messages
  • Printer will not "wake up" from sleep mode
  • Printer appears to be DOA
  • Incorrect printout
  • Slower than normal printing
  • The printer control panel display is blank or shows garbled characters
  • Accessories, such as attached copier/scanners, do not function properly
  • Monitor loses power or shuts off
  • Computer reboots when job is printing
  • Job only prints half way, causing a paper jam
If it is necessary for the product to be connected to the above-mentioned devices, consider the following items:
  • There are many UPS configurations and load conditions that can affect proper printer operation. Depending on these configurations or load conditions, printer functionality cannot be predicted.
  • No damage to current HP LaserJet products will occur, but, depending on their particular UPS configuration, the printer may or may not operate properly.
  • Printing while on a UPS battery backup is not recommended because of the large power requirements of HP LaserJet products.
  • If the HP LaserJet printer is not operating properly and power line conditions are suspected, try a different circuit (a different wall plug located away from the current one), or try removing it from the UPS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | HP LaserJet P2015n Printer
I am unable to print on both sides of my hp p4015n printer. I have also checked the print on both sides icon, please advise
The most easy way is to uninstall the existing driver// restart the computer and from hp.com reinstall the full feature driver for your printer//
Jun 29, 2010 | HP LaserJet P4015N Printer
Hp laserjet 1200 series printer with high pitch nose when in printing process. During this loud noise, the roller turns but the paper is not picked up therefore printing does not occur.
noise is caused by the toner cartridge and paper is not going trough because there is a plastic milar clse to the feed roller that is bent,find it and push it towards the inside of printer (is a black or dark brown plastic mylar)
Aug 24, 2009 | HP LaserJet 1200 Printer
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
High pitch noise
Very bad. HP is crowd of fools, getting started to **** a brain to us.It was very good printer producer,now I dislike it more and more.
Dec 19, 2007 | HP LaserJet P3005 Printer
HP LaserJet P4015N Printer Logo
1,512 people viewed this question
Clive
Clive
