Question about Honeywell Programmable Thermostat Heater
I can't get the furnace to come on when the inside house temp drops below the set point on the thermostat. If it does come it does not stay on long enough to raise the house temp. HVAC guys here two days ago and serviced the furnace. Was having similar problem then and told them about it. Furnace was working while they were here - it looked like everything was ok then Do I need to replace thermostat? or does it need to be adjusted?
    Scholar:
  • 81 Answers
Sounds as though another problem is showing up. Verify T-stat is sending the red 24volts (alt current) through the White wire. This can be done at the t-stat or the furnace whichever is easier to access. At t-stat your meter will show 24volts from red to any wire that the t-stat is not jumping to. So if you put on lead on Red and other on White and 24 shows up the t-stat is not connecting that and the furnace will (NOT) turn on heat. If you get 24 on Y or G but nothing on White then the t-stat is (Good) and the furnace in not kicking on.
To diagnose furnace look for flashing light on board. count flashes and read furnace diagram for info. Furnace diagnosis will take some patience and observation of what happens when. Problems can be Airflow, or parts. It takes some watching. I've found tools jammed in vent stacks, blocked (dirty) evaporators and failing sensors or relays. All causing the units to start but not stay lit.
Posted on Feb 14, 2011
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
In house temp is high and furnace stll goes on
Might be dust in the thermostat. Filters might be dirty. I would call a service man before the house burns down!
Apr 01, 2014 | Honeywell Digital Round Single Stage...
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Furnace burner only coming on short time
The problem is inside the furnace. It can be several reasons. Look at the "Klixon" switch near the burner. It usually goes first. Then there's a thermocouple that has a sensor that must have the flame touching it in order to hold the gas valve open. The wiring diagram on the furnace has all the safety and operational components to check.
Jan 24, 2014 | Ruud UBHC Air Conditioner
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow...
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
Jun 21, 2017 | Heating & Cooling
Furnace will heat to desired temp and flame will go out but fan continues to run
This is normal to a point. A thermostat turns the furnace on and off as you know. However there is a separate thermostat, usually on the side of the plenum that runs the blower fan. It will keep the fan running until the air temp in the plenum drops below a certain temp and then turns the fan off. If it's not shutting off at all then that thermostat is likely bad and will need to be replaced. Hope this helps.
Sep 12, 2011 | 2002 Chevrolet Trailblazer Ext
I have a ruud model no. ubhc-17j11nfd and i am having a problem with my heat. when the heat does come on, the thermostat says it is on auxilary heat. i am getting no suction from inside the house but the...
If you haven`t changed your furnace filter do so. If there still isn`t any air flow then the evaporator coil is plugged with dirt and needs cleaned. It is inside your furnace where the pipes from the outside unit connects. As far as the auxilary heat, this is normal when the house temperature drops to far below the thermostat set point and they will turn off when the house is close to temperature and lets the heat pump take over.
Feb 02, 2011 | Ruud UBHC Air Conditioner
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
170 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
