Question about Sony Ericsson XPERIA X10 Cell Phone
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing happend...can you help?
    New Friend:
I try to format more than 10 times bt the problem can not solve it Y?
Posted on Nov 13, 2013
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Try formatting your SD card by plugging in Laptop's or using a memory card reader. Don't use the cell, after formatting insert in cell and re-format. it will work.
Posted on Nov 10, 2010
2 Suggested Answers
SOURCE: i am getting error message that sd card is blank
The problem could be your SD card. Try your SD card on a friends phone. If the same problem occurs, get your SD card repaired. Most SD card companies provide you with unlimited warranty so there should not be a problem.
Posted on Aug 01, 2010
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
I am getting error message that sd card is blank and/or when i want to use my camera error message comes as insert your sd card..i try to format the sd card by following format sd card section but nothing...
Aug 01, 2010 | Sony Ericsson XPERIA X10 Cell Phone
My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
Jun 07, 2010 | Kodak EasyShare C310 Digital Camera
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My hdd is full and I want to record on a 16GB SD card. When I insert it and try to format it does not format and I get a message state memory card error.
few, if any, SD cards larger than 2GB are SDIO compliant. Most cameras which take SD require SDIO-compliant media. Try a branded card (eg Samsung, Kingston) which is certified SDIO media.
Jul 03, 2009 | JVC Video Cameras
SD card - memeory card parameter error
Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
Jun 12, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Sony Ericsson XPERIA X10 Cell Phone Logo
710 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
