Question about Lexmark E250dn Laser Printer
My Lexmark E250dn is constantly having paper jams, if I print more than 10 pages at a time I always have to stop and fix it, are there any solutions?
  • 21 Answers
Check the paper feed path if everything is cleaned out and aswell your exit sensor.
If that dosent help clean you pick up rollers.
Also give me more details on more or less where it jams in the printer?
Posted on Nov 10, 2010
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Lexmark Prevail Pro705 printer jams each attempt to print. Reasonably new, Lexmark just replaced printhead and ink cartridges under warranty and printer gave better print results than when brand new. Joy...
Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update on your computer. The update will make your printer more reliable and more efficient.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Amber "Paper" light constantly flashing. It has
This light sequence means that the printer prompts you to load a single sheet of print media in the manual feeder. What you can do is load paper into the manual feeder and press Continue to resume printing. Press and hold Cancel to reset the printer.
For further assistance, please call Lexmark Technical Support.
Apr 26, 2011 | Lexmark E250dn Laser Printer
My Lexmark E250dn laser printer is not picking up the paper to print. It sounds like it's trying then it jams up.
I had the same problem on my E250dn. First remove the paper tray. Shut off the printer. Tilt it sideways if it's manageable. Then, clean the 2 rollers directly underneath the printer with alcohol. That solved my problem and hoped yours as well.
Apr 19, 2010 | Lexmark E250dn Laser Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Printer constantly jams
If I could be of further assistance, let me know. If this helped or solved the issue, please rate it.
Thanks, Joe
Apr 10, 2009 | Lexmark E250dn Laser Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Paper jam Lexmark E250d
I hate to state the obvious and I am not patronising you, but is the rear door fully closed (did it click into place) - probably. I wonder how many pages the printer has printed? If you are lucky you might be able to print out a demo page (hold the "okay" button down - the large one with the diamond/triangle on it). If it is a high number (say over 10,000 pages) then perhaps the paper pick rollers have stopped working? Also, what paper are you using? Heavy (100gsm or above) or thin (under 75 gsm) may have feed problems.
If this doesn't work you could always try printing to the rear door - this would probably stop the jam hopefully. This would enable you to print a demo page at least so you can see its page output.
Hope this helps you out.
Aug 09, 2008 | Lexmark E250d Laser Printer
Lexmark E250dn Laser Printer Logo
470 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
