Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
So I tried turning the washer on this morning and the washer would turn on for a second and then turn off. do you think the timer is going out?
    Genius:
  • 1,672 Answers
Ur right about that! Timer mechanism is about to get BUSTED! Inside that timer there are contact points were a rotary point hit one and makes the motor and solenoid to activate in a certain time! Better look for a PART for that and replace it! Hope that make you one TECH minded person to know that problem! taaah!
Posted on Nov 10, 2010
I think my timer is not working ,I set time is 30min. hit start and it is running for approximately 30 seconds then machine stops right hand side (all indication flashs
Good morning friend, I appreciate your post!
I understand that your Frigidaire washer will start but after 30 seconds it will cut off and all your indicator lights will flash. It could possibly be a miscommunication with the board I would try to reset your appliance, you can do this by unplugging the power cord or flipping the household circuit breaker for ten minutes. Could you comment back I would like to verify if that helped? I look forward to your response. -Matt
Jul 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
Had 04 transit connect for 6 weeks. always started fine till week ago when turned cold. glow plug light only shows for about 1 second, replaced glow plugs but still the same. can only start every morning...
Sounds like the timer is bad. Since you have power when warm, the power relay must be giving the timer juice. The way it is suppose to work is you wait until the glow plug light goes out and then try to start. In cold weather it should take longer for the glow plug light to go out.
Nov 03, 2013 | Ford Transit Connect Cars & Trucks
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Was working fine and went to put in 2nd load and water came out for a second and then all together stopped
hmm, I can think of a few things that would cause that.
First thought would be the water valve: this is a valve that has two solenoids on it, one for hot and one for cold they mix to one outlet that goes to a spout into your washtub. Try different temperature settings for the water. If cold does not work, see if warm does, if it's nothing but hot water coming out, then it's either the valve or your timer.
Second is the timer's not sending power to the water valve to turn it on.
Third would be the water level switch, if it is bad it may be prematurely telling the washer to go into agitate mode. If after the water stopped it went to agitate mode then it very well could be the water level switch.
Oct 30, 2009 | Maytag LAT3600A Top Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
