Question about Whirlpool TEDX640PQ Dryer
My dryer, Model TEDX640JQ1, stopped drying. It runs cool air only. I cleaned through the lint vent with a brush. I also checked the back hose to make sure that no kinks were there or a clog. I know that now I need to get inside to check if there is lint clogged. But, where do I get into it to check this? Does the back need to be removed?
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
Maytag dryer will not restart immediately after drying a load. has to cool down
try cleaning out your dryer vent. Remove your lint trap and use a flexible wire brush to clean deep inside, then remove your dryer vent hose and make sure all lint is clean from the dryer side of the vent and the vent hose all the way to the out side vent.
Sounds like it may be clogged with a build up of lint
May 23, 2012 | Dryers
My dryer is heating fine but there is no air blowing out of the vent. Therefore, clothes are not drying properly. I have cleaned the lent filter, checked the outside and and inside vent for clogs or...
run the dryer with the vent hose off, if it drys correctly then it is in the vent tube. The best way to clean the vent hose is with a leaf blower, now if it is not drying with the vent hose off then you will need to disassemble the dryer, and clean from the bottom of the lint trap back to the back of the dryer with a brush(paint) and a vacuum:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have had this elect dryer for about 3 years. Same prob from the start.. Takes forever to dry any load of clothes.. Litterally 4 plus hours to dry 5 bath towel and 6 or 7 wash cloths.. this is...
Long drying times can commonly be the result of improper or restricted venting.
Examine your vent hose. How long is it? Too many bends?
Check to make sure your vent hose is clear and free of an restrictions.
If vented outside, is the flap opening properly and free of lint buildup and is the hose clear?
Pull your dryer away from the wall and disconnect the vent hose, use a vacuum or brush to clean out the inside of the hose, sometimes shaking the hose a bit (if possible) will free any lint buildup that your vacuum or brush may have missed.
Don't overlook cleaning out the pipe that the hose connects to on the back of the dryer.
Lastly if you have a lint filter that's on the top like mine, remove the lint filter and check for obstructions there, use a lint filter brush and clean well, this is often overlooked and a major cause of poor drying, overheating, or fire.
Feb 11, 2011 | Dryers
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Whirlpool dryer wed5700sw
you need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
My Miele T8322 Tumble dryer turns off before the clothes its fully dry even in Extra Dry mode. The vent pipe is clear. Is there any kind of adjustment or do I need to get a new sensor under warranty...
IS THE DRYER PUSHED UP AGAINST THE VENTING IN THE BACK OF THE DRYER? IT MAY BE CRIMPING THE EXHAUST MATERIAL CAUSING A RESTRICTION.
IF THAT IS O.K., DISCONNECT THE EXHAUST AND RUN A LOAD OF LAUNDRY THROUGH A NORMAL DRY CYCLE.
IF THE DRYER DRIES THAT LOAD O.K., THERE IS A RESTRICTION SOMEWHERE IN THE EXHAUST. ALSO, CHECK THE LINT TRAP. IF THERE IS A WHITE CLOUDY FILM ON THE LINT FILTER, TAKE A WIRE BRUSH AND CLEAN IT OFF. IT IS RESTRICTING THE AIR FLOW AT THE FILTER.
CHECK THE LINT FILTER HOUSING FOR A BUILD UP OF LINT. IF THERE IS, USE A CENTER CARDBOARD FROM WRAPPING PAPER ATTACHED TO THE END OF THE VACUUM HOSE. FLATTEN THE CARDBOARD TO FIT INTO THE FILTER SLOT AND CLEAN OUT THE LINT.
Apr 22, 2008 | Dryers
Whirlpool TEDX640PQ Dryer Logo
211 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
