Hydronic Electric Baseboard Heater - PLF2004D - 90 in 240 Volts / 2000 Watts / 8.3 Apps Yes, using 240 volts Just purchased hydronic heater (Marley/Fahrenheit). Everything is good, except 1 major problem......it 'pops' The heat keeps 'popping' on and off every few seconds. Seems likes it 'pops' when obtaining heat and then stops 'popping' once at temperature. This is the 2nd time after replacing formal, thinking it was a one time problem. This is in my bedroom and is flat on the floor, and is not screwed in to the wall yet. I heard do not screw too strong into wall and that is what causes a problem. All other hydronic heat in the apt is perfect, quite as can be..........never, ever hear it 'pop'. Please help with your comments and suggestions. I need the heat and I can't sleep with it 'popping'!
  • djmagnone Nov 12, 2010
    Thank you for your response. I did install on my wall yesterday and it is approx 1/4" off the floor. 1 screw on both sides and (not screwed too much, say returned by 1)
    Unfortunately, still poping. Sometimes loud, soft, even not poping, and at all diverent points. Good news, atleast the heat works.
    This is my 3rd replacement and its still poping, again none of my other hydronic heaters are poping at all.
    Can you recommend another company that offers hydronic electric heat?
    Thank you all!
    President:
  • 1,796 Answers
Hi!!
Make sure there is 240v present, there are some safety devices installed that prevent unit form working if there is a problem. In this case, I believe being on the floor and not properly installed is causing the the heater to cut off. Click on the following link to watch a video on proper installation. http://www.cadetco.com/installvideo.php
Once you're sure the unit is properly installed, click on this link for troubleshooting and maintenance tips http://www.cadetco.com/FrequentlyAskedQuestions.php
If you need further assistance, just place a comment.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 10, 2010
  • Rene J Solis Nov 12, 2010
    Hi!!
    I am glad you have your heater going. Check this site http://www.hydrosil.com/, I've heard this heaters work pretty good and are practically service free.
    Good Luck and Thank You for using FixYa. Don't forget to rate this post :-)
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
What braker for 240 volts 500 watts 2-1 amps
if you are running a new circuit for this one heater than a simple 2-pole 15 amp breaker will do fine, it is also acceptable to use a 2-pole 20 amp breaker, as long as you are in the united states. since you have such a small unit you can put 7 of these heaters on one 20 amp breaker.
Jul 21, 2010 | Fahrenheat Electric Hydronic Baseboard...
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Marley Hydronic baseboard heater not turning on
on the one that don't work use a clamp around ammeter and see if you are drawing current. no current, the heater element is shot!
Oct 23, 2009 | Marley Electric Hydronic Baseboard Heater,...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
