Question about Microsoft Windows Vista Ultimate Edition
Utorrent. the port problem had been solved. but the connection is still yellow
    Master:
  • 382 Answers
Please check if the port allocated for u-torrent is port-forwarded properly..also check you have assinged a unique port number for u-torrent program..go to options tab in u-torrent and speed guide options in it and check the assinged port number!..or u can visit www.port-forward.com to port forward for the u-torrent!..thank you !!..
Posted on Jun 19, 2008
Slow downloading speed
Make sure that your port is open on your router to allow the connections. This setting is under the options in the software. You can follow this from the site to walk you through:
http://www.utorrent.com/documentation/connection-setup
That will allow you to connect to more peers. Also, make sure you have more seeders in the swarm. Good luck!
Oct 22, 2009 | SENAO High Power 200mW USB WiFi 802.11bg...
Problem opening port for utorrent with DGL 4300 router
You must set static IP on your computer where the utorrent is installed. Make sure no firewalls are enabled on your computer like windows firewall or any other firewall like norton, mcaffe, zone alarm and the likes. You should forward the port on separate protocol. Go to portforward.com for more information on how to forward port for utorrent
Jun 14, 2009 | D-Link GamerLounge DGL-4300 Router...
Setting ports
Hello, I went through this with utorrent when I first started and I had trouble with my router not opening the port. When I hook directly to the modem the port is open. But after much research I found that you don't have to have the port open, it just enables other to download from the items that you are seeding. Works just fine either way. Enjoy.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 09, 2009 | Computers & Internet
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
Mar 21, 2009 | Zhone (6218-I2-200) Router
Problem with jetspeed 520 and utorrent.
Please add the utorrent service on the policy which permits traffic from your LAN to internet.
Nov 10, 2008 | SonicWALL (01-SSC-2488) Firewall
Port opener
Go to options>preferences>connection
You can set the port there and also Upnp mapping so that if your router is upnp ready it will be automatic
Aug 22, 2008 | Computers & Internet
Utorrent port.
you need to manually add it in the port forward section of your router interface. typically a range of 10 - 20 ports. make sure it matches the ports listed in the utorrent options page.
Jun 27, 2008 | Computers & Internet
Firewall/ports
Hello there, you only need to open a port for utorrent, if you use a Router device for sharing your internet connection to more than 1 computer. If you do indeed own a router then you will need to log-in to it, via your web browser and change the necessary settings to forward the port that utorrent uses, to your local computers address.
Please write again if you need more support.
Hope this helps.
Apr 06, 2008 | Symantec (10427438) Firewall
TEW-452BRP - can't open a port (forward)
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Feb 23, 2008 | Trendware TEW-452BRP Wireless Router...
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Microsoft Windows Vista Ultimate Edition Logo
270 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
