Question about Insignia NS-LCD37 37 in. LCD TV
The code on my remote is CRCR351 I do not find this number on the code list, after following all instructions I still cannot program the remote, do I have the wrong kind of remote?
Rca remote model number CRCR351, R2O474, 2T39EW Need code hook remote to my seike tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Dec 14, 2016 | RCA Televison & Video
How to get rca crcr351 remote to work with rca rled1945a
Programming Notes
Oct 26, 2016 | RCA Televison & Video
My wave cable hd dta remote will not turn offandontv...repair guy said to ask vizio
Use the following instructions and code list to program your VIZIO Universal Remote Control. Press the TV (or device) button and hold for 5 seconds until the LED flashes twice. LED will remain lit. Find the programming code for your TV (or device) in the code list and enter it using the Number Buttons.
try a universal remote and program it, from the manual.
3 Digit Universal Remote Codes For TV Codes For Universal Remotes
4 digit GE universal remote control codes with code entering instructions
http://www.remotecodelist.com/
http://cdn.vizio.com/documents/downloads/vizio-universal-remote-codes.pdf
Feb 03, 2016 | Vizio P50HDTV10A 50 in. Plasma HDTV
Need instructions how to program a one for all remote to a flat screensansui or the code for it please
Do a google search of the remotes make and model number located on back or possibly behind the battery cover. Should be able to come up with a code list for your remote then you just find your tv brand in the list and use that code when following the programming instructions
Nov 25, 2014 | Televison & Video
How do you program in a tv
Your remote should come with a pamphlet which has instructions on how to do this. The pamphlet should include many codes for different types of TV's and instructions on how to enter them. Find the code for your model of TV and follow the instructions. If you cannot find your pamphlet, this website has a list of all TV, VCR, and Cable box codes. Some devices may have multiple codes. If this is the case then simply enter each code consecutively until the remote works. If you cannot find your pamphlet, then you can try following these instructions-
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Jun 01, 2011 | Televison & Video
I need instructions on how to set my RCR312W for a Samsung TV, just the TV
Hello
There are four digit and five digit codes that can be synchronised with Samsung TV to RCR312W.
Four digit codes are:
1004, 1005, 1006, 1012, 1013, 1015, 1017, 1019
Five digit codes are:
10812, 10054, 10060, 10702, 10178
Instructions:-
Direct Code Entry
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to
control
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand.
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Jun 01, 2011 | RCA RCR312W Remote Control
I sansui tv and remotei have is 3 in 1 universal
Go to radioshack.com under tv remotes insert your model number a manual will come up. Go to program remote and find your tv code and follow programming instructions.
Jan 23, 2009 | Radio Shack (15-2147) Remote Control
Programming my remote
Here is a link for the generic programing instructions for the RCA universal remotes. Scroll down the page for a list of device codes.
Let me know if this is what you were looking for.
http://www.thompsontv.com/rcarc.html
Dec 28, 2008 | RCA RCR311B Remote Control
Codes
try the following codes until one of them work:
002, 003, 004, 005, 006, 007, 008, 044, 045, 046, 053
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press the SET button.
  3. Press the appropriate component button for the component being set up.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
NOTES:
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
Nov 23, 2008 | Sony RM-V310 Remote Control
53sbx59b Hitachi 53 inch proj tv
Call the 800 number with the new remote. Sometimes they will have additional codes. Or with the instructions with the new remote you can manually get it to work. You must follow instructions carefully. Look for this section in the instruction booklet
Dec 29, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Insignia NS-LCD37 37 in. LCD TV Logo
147 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
