Question about HP Photosmart C5180 All-In-One InkJet Printer
How to set printer as default - HP Photosmart C5180 All-In-One InkJet Printer
  • HP Master
  • 7,733 Answers
Go to : Control panel Printers Select the printer Right click and select "set as default"
Posted on Nov 10, 2010
  • 92 Answers
  • Click on the Start menu and click on Settings, then Printers.
  • A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
  • Click on Set as Default
  • To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
  • Read more: How to Change the Default Printer ' eHow.com http://www.ehow.com/how_6097_change-default-printer.html#ixzz14tGsLTEN
    please leave feedback if this helped you :)))
    How to delete previous owner WiFi data and security code
    Resetting the Printer to Factory Default
    Settings
    Resetting the printer to factory default settings can be useful when
    you are troubleshooting with the printer.
    CAUTION Resetting factory defaults clears the page buffer, removes downloaded
    fonts and macros, and returns all print menu settings to factory defaults.
    To reset the printer to factory default settings
    1 Press MENU until RESETS MENU displays.
    2 Press ITEM until RESTORE FACTORY SETTINGS displays.
    3 Press SELECT until the following message appears:
    RESTORING
    FACTORY SETTINGS
    This message displays until the printer has completed the
    initialization
    Mar 26, 2015 | HP LaserJet 4500 Printer
    How to delete former owners wireless data on HP 4500 - G510n wireless printer.
    Settings
    RESTORING
    FACTORY SETTINGS
    initialization
    Mar 26, 2015 | HP Office Jet 4500 G510n
    Error 5
    If no default printer is selected, or no printer driver is installed, Printer Error #5 is displayed.
    Select a default printer in Windows by going to your Control Panel > Printers. Highlight your Printer and go to File on then Menu Bar and choosing Set as Default.
    If the correct printer is already set as the default, and you get Error #5, try setting another printer as the default printer. Then select and set the desired printer as the default, and reboot the machine. This sometimes clears the problem.
    If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
    Mar 15, 2013 | Canon PIXMA MP150 All-In-One InkJet...
    Printer t2280+ displays paper width error after printind only one line and stop . even on selftest without connecting to the system
    Hello
    When using the Show method of Data Report to preview the report, the page orientation defaults to the default printer settings on the local computer. Therefore, if the orientation of the default printer settings is set to Portrait of standard Letter paper and your report width is more than 8.5 inches wide, the following error occurs:
    1. Make sure that there is no extra white space in the report. If there is any extra white space in the report, close up that section so that the ruler falls within the width of your default printer.
    2. Set your Left Margin and Right Margin to 0.
    3. Check your printer setting to ensure that your default printer is set up correctly. If the report is landscape (that is, greater than 8.5 inches) the default printer should be set accordingly.
    Jun 29, 2011 | Office Equipment & Supplies
    I have an HP Photosmart C7280 Printer wireless connected. The Pause Printer and Use Printer Offline are always checked on. How do I change the default status on these 2 items to default off. Whenever I...
    To change the default printer settings or to restore the settings in your printer, click on the start menu, select Settings, and then select "Printers" from the menu that appears. After that you could right-click the printer that you would like to change settings for, and then select "Properties" from the menu that appears. This would open up a tabbed window that would display many settings that you can change. You could change the settings you need to change or there is another option that you would find to restore to defaults, this would allow you to set the default settings on your printer.
    Jan 06, 2011 | HP Photosmart C7280 Printer
    Trying to copy a document. I'ts 8.5 x 11. It's only copying the upper right corner of the document. Can't figure out why. Help.
    Reset the printer to default settings.
    1. Press Setup.
    2. Go to Defaults.
    3. Go to Set Defaults.
    4. Select Use Factory.
    5. Hit Ok to reset the printer to factory default settings.
    6. Reconfigure the printer with the printer settings (Country, Time, Date, etc.)
    7. Try copying.
    NOTE: Wireless connection won't be affected when resetting printer to default settings.
    Oct 12, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
    How do I set up Canon 8500 printer defaults in computer? I print manuals as needed that require 2 sided,colored covers then stapled. There used to be a manual default to select but was erased accidently.
    hi there,
    You can change the default printer to any other printer that you have connected to your computer. This will simplify your printing tasks, since you can select the most frequently used printer to be the default.
    1. Click on the Start menu and click on Settings, then Printers.
    2. A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
    3. Click on Set as Default.
    4. To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
    Hope this initial info/idea helps.
    Apr 24, 2009 | Office Equipment & Supplies
    How can I permanently alter the Default Print Settings?
    In the control panel, you can select your printer and set defaults. You can also set them in your printer's setup & maintenance program.
    Jan 31, 2009 | HP PSC 2210 All-In-One InkJet Printer
    Printer Defaults
    try setting up your sizes etc on the required printer in" printers and faxes" first and then access your print system , when you then select the "print" function you will find the sizes etc that you have set up in printers and faxes are already set for you , unfortunately it will only save for a few prints and then will default ,however it defaults to the settings you have already set up in printers and faxes
    Jan 27, 2008 | Zebra Printer 140-751-00000
    Lexmark t420 all leds are on
    What this light sequence means:
    • The printer is processing a request to cancel the current print
    job.
    • The printer is resetting to the user default settings. Any active
    print jobs are canceled. A user default setting is one you select
    and save which is different from the factory default setting. A
    user default setting remains in effect until you make another
    selection and apply it or until you restore factory default settings.
    What you can do:
    Wait for the message to clear. It clears when the printer finishes
    processing the cancellation request or when it resets to the user
    default settings.
    Oct 24, 2007 | Brother HL 1430 Laser Printer
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    496 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
