Question about Keurig Ultra In Home Single Cup Brewer with 54 KCups
My keurig is dead. I think is an electrical problem. Do you know a repair shop I could take it to??
Parkinglights not working , blows the fuse when you turn the switch on.
What make , model and year ? You have a dead short to ground on that electrical circuit ! Do you know how to test automotive electrical circuits using a volt meter and a wiring diagram so you know which wires to test ? If not , your best bet would be to take it to a qualified repair shop.
Aug 03, 2017 | Cars & Trucks
Keurig won't come on
Vanessa, If not too old return for exchange. links below show how to diagnose problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Your Keurig Coffee Machine if It Won Turn On eHow
Dead Keurig brewers
Single Serve Coffee Forums
Feb 28, 2016 | Keurig Coffee Makers & Espresso Machines
Where can I get a Keurig brewer repaired other than from Keurig?
If it is one of their better systems they (Keurig) will replace (free) if it is a defect, or worn out. If you broke it, well.... it would be more cost effective to replace, than pay the minimum a repair shop would charge to repair. If you have not called them (Customer service) I would do so. They have the option, to offer large substantial discounts to a current customer wanting to replace, or upgrade their existing brewer, and it will be direct shipped from the factory. It is worth the call, all you have to do is ask.
Jan 17, 2015 | Keurig Coffee Makers & Espresso Machines
My Keurig was accidentally plugged to a 220 v outlet instead of a 110. Need a repair shop located in the Philippines. . It won't operate anymore.
Chances are pretty good that you blew a fuse in the unit. I think it would be worth it for you to take it apart and check. If there is not a fuse you have lost nothing.
Nov 13, 2014 | Keurig Elite B40 Coffee Maker
Why will my Keurig B60 not turn on?
If it worked before you packed it, circuit can't be burnt. Try it with any electrical/electronic repairer please.
May 22, 2014 | Keurig B60 Coffee Maker
The unit is completly dead
Good evening to you
So no coffee for you tonight
I would try taking the coffee machine to the shop it came from or does sells the same type, and ask what is wrong with the electricity.
good luck
Kolbrun
Feb 26, 2012 | Keurig Ultra B50 1-Cup Coffee Maker
My keurig died. It will not power on at all! I have tried different outlets and turning the switch on and offf.
sounds like a bad machine,perhaps just the switch went dead. If you have any know how you can open it up and try chaning the switch or you can try contacting Keurig directly and see if they will honor the warranty, if that doesnt work i know of this great website that sells all kinds of keurig products for very cheap.http://stores.ilikenew.com
Jan 30, 2011 | Keurig Platinum B70 Coffee Maker
I have an old Black & Decker twin blade electric mower that just died. I took apart the motor and it looks pretty dead, I think a short in the windings most likely, but the brushes are worn out and the...
find your local electric motor repair/rewinding shop and take the old motor there
ask what you could get to replace it
consider that the new motor will probably be better if it is a bigger hp unit as grass ( especially wet grass) is hard to cut and B&D would only install a motor that only just does the job
Mar 12, 2017 | Black & Decker 18", 6.5a Electric Mower
Friends 1997 honda civic wont start or take a jump just dead. any ideas
Can not charge a dead battery, that is very old or bad internally. If battery is new or you borrow a good one to proceed, you have the cables.bad grounds,starter issues. If you have no veh or electrical knowledge you know what to do. Pay the repair shop
Sep 29, 2009 | 1997 Honda Civic
Keurig Ultra In Home Single Cup Brewer with 54 KCups Logo
139 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
