Question about Electrolux Dishwashers
Electrolux Dishwaher ESL424 Water going to appliance. Program selected, door closed, sounds like its starting up and then makes a "racket". Door opened and no water in appliance. Any advice
  • Electrolux Master
  • 3,247 Answers
The inlet water system apears to be causing the problem.
This model has a water softener unit which should provide the water to run the dishwasher.
See this diagram..The hoses and the container on the left side are part of the inlet water system.
If the softener is empty then there will be no water coming through.
It might help if you provide a more clearer description of the "racket" you mention. For example is it clicking of the relays in the timer. Is you inlet water tap open.
Posted on Nov 10, 2010
Electrolux dishwasher won't run through a cycle?
So it would be desirable to write the ERROR appeared in
Dado
Aug 02, 2014 | Electrolux 24 " White Built-In Dishwasher...
Electrolux cde7700lw0 dryer
Good Afternoon Brain, this is Z. I am happy to assist you!
I understand that your Electrolux dryer (CDE7700LW0) door indicates it is open and your dryer will not operate. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your dryer. Select a normal cycle and verify if the dryer will start. If your appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Apr 10, 2014 | Electrolux EIED55I Dryer
Electrolux ewf 1029. What's wrong with it?
Something not working? Problems which you can resolve yourself, before calling the After Sales Service.
During machine operation it is possible that the end light
4 flashes= the door has not been closed
2 flashes= the machine does not empty
1 flash= the machine does not fill.
Once the problem has been eliminated, press the START/PAUSE button. In the case that the blown fuses due to consumption exceeding 10 amps and also have problems with the front cover microswiche which is not activating when you close the door. You should check the condition of the engine and change the microswiche of the door. Remove any objects from the pump impeller by rotating it.
Jul 28, 2011 | Washing Machines
Hi there, I have an ESL424 Electrolux dishwasher and I'm having some problems with it not washing dishes properly. Is there any common reason for this? The problem seems to be more apparent in the top...
first thing is to ensure the top spray arm is turning freely. make sure nothing is blocking it, for example one of them dishwasher fresheners.
also check the holes on both spray arms to ensure they not blocked up, also if you can remove the spray arms and clean them out, also clean out the filter.
i also always susjest putting the upper basket on the highest setting as high plates etc. in the bottom basket can stop spray arm turning
after checking all of the above, put the spray arms in the 12 o clock posistion and turn the dishwasher on, when it starts washing open the door to see if they have moved.
also always use a good quality diswasher tablet, cheaper ones dont always give good wash results.
Jun 25, 2011 | Electrolux 18 in. ESL424 Built-in...
Dishlex 300 blobal dishwasher. have set dishwaher for normal wash as usual. All lights are one but dishwaher will not start. help please
It is likely the door switch is not engaging properly. Check the gasket is set properly and the door is closing when you shut it. Also confirm if it is not on delay start.
Feb 13, 2011 | Electrolux Dishwashers
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
WATER NOT FILLING
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Nov 04, 2009 | Electrolux 18 in. ESL424 Built-in...
ESL424 Water switch
look for a plastic tube that leads to the switch most likely near the main control board (behind control panel)...possible the tube lands on ta board-mounted switch. the tube, at the switch end, should never have water in it. it is merely testing for air pressure which is directly proportional to the water level because of the opposite end of tube.
Apr 19, 2008 | Electrolux 18 in. ESL424 Built-in...
Dishwasher fault
If you have tried to run any cycle and still end up with this problem, then most likely a failed timer unit. The next step is for the water switch to enact the next step which is to start the timer.
Jun 17, 2007 | Electrolux 18 in. ESL424 Built-in...
Dishwashers Logo
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
