Question about Zebra Eltron P520 High Speed Printer/Laminator (P/N P520C-E000U-ADO)
Error message i have eltron card printer when i power on the printer there is massage Mechanical Error Ready on the printer display what i will do pls. answer me urgent thank
  • 689 Answers
Issue related stuck due to objects such as paper or plastic. make sure its clean and gears are moving.
Good luck
Posted on Jun 17, 2008
Dir.hp hp p1005 printer engine error massage what
Are you connected to a PC or a MAC? Is the error displayed on your PC or your printer? Is there a number associated with the error? Please provide the number at the exact error message.
Or, you can go to HP.com/support and drivers and research the error message.
Aug 18, 2013 | HP LASERJET P1005 Printer
Error 3 massage comes in hp deskjet 1315 all in one printer
would to me what the error messages
If expired cartridges are present in printer, the printer will not be blocked but error message\light will be displayed to replace cartridge.
If expired cartridges are replaced with new ones the issue should be fixed.
Feb 27, 2013 | HP PSC 1315 All-In-One InkJet Printer
I have an HP 4000N printer that is showing an E10 error. Can you advise what the problem is? Thank you.
EIO Error: Has to due with the additional card or hard drive on the back of the printer. If it's a networked based printer try the following:
Power off machine and unplug power cord.
Remove the network card from the EIO slot
Remove the cover from the other EIO slot (either below or above) and insert the card into that slot.
Power machine back on, see if error comes back.
If error is still present:
- Remove the card turn machine back on and see if the displays comes to ready.
If machine does come to a ready state than I would recommend:
- Replace the Network Card
If after replacement of card and attempted both EIO slots. Then you will need to replace the formatter.
Hope this helps!
Mar 07, 2011 | HP LaserJet 4000n Printer
I have an error message on screen, 18 aux I0 not ready what does this mean
It means the modular I/O card is not ready. Check the MIO card documentation. More then likely, the printer will display this message until the problem with the card is corrected. You can check to see if this is the problem by removing the card and seeing if the error message is still being displayed. Be sure to check your documentation for the correct procedure to remove the MIO card. Faiture to follow the manufacturer's directions and recommendations can cause harm to your computer or possible loss of valuable data.
Jun 07, 2009 | Office Equipment & Supplies
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart C6280 All-in-One i have an Error massage (Ink System Failure)it says: ink system has failed. unable to print. refer to printer...
ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
Press and release the “OK” button.
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
Oct 02, 2008 | Office Equipment & Supplies
Machine error 41
Machine Error 41 indicates a mechanical malfunction with FAX/DCP/MFC.Often, unplugging the unit from the power source and then plugging it back in again can clear this error message.If the message continues to be displayed on the LCD, please contact YOUR PRINTER Customer Service for more options.
Sep 16, 2008 | Office Equipment & Supplies
When going to print to a laserjet 4000pclx printer I get an error code 7900FE. What is it and how do I fix. it.
If you have cleared the print queue so there are no outstanding 'faulty' files; it's worth knowing that the 79.00 error can also be caused by poorly fitting or incompatible memory cards.
To clear the printer queue on PC
click on start
click on run
type: services.msc
scroll down to print spooler
right click on this service then press restart
exit out and try again other wise continue below..
Can you make sure they are firmly mounted?
Remove all communication cables so that only the power cable is connected.
Remove the Jetdirect card, if installed.
Remove any other accessories, such as the envelope feeder.
Hold down the green "GO" button.
Turn the printer on.
When the words "Cold Reset" appear in the display, release the green "GO" button.
When "Offline" appears in the display, press the green "GO" button. "Ready" should appear in the display.
NOTE: If the words "Cold Reset" do not appear in the display, hold the "GO" button down until you hear the motors rotate. The words "Restoring Factory Settings" will appear in the display if the "Cold Reset" was performed successfully.
Turn the printer off once the printer displays the “Ready” message.
Reinstall each of the above-mentioned components, one at a time, turning the printer on and off again each time a component is installed.
Continue installing and power-cycling until all accessories are installed and the printer is at a “Ready” state.
If it is determined that one of the components is responsible for the 79.00FE error, refer to next.
If the printer will not return to a “Ready” state after removing all of the components and performing the cold reset, try a different power source by moving the printer to a different location and plugging the power cord directly into the wall.
If the printer continues to display the 79.00FE error, upgrade the firmware. A firmware DIMM can be obtained from the HP Parts Store at http://www.hp.com/buy/parts . Version 6.36 Firmware DIMM is Part Number C4251-67905; however, part numbers are subject to change without notice.
If the printer still continues to display the error, contact HP for further assistance.
Jul 28, 2008 | Computers & Internet
Error
while power on display massage eerror c00e0402 . how to solve problem?
Oct 23, 2007 | HP PSC 750 All-In-One InkJet Printer
Zebra Eltron P520 High Speed Printer/Laminator (P/N P520C-E000U-ADO) Logo
346 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
