Question about Bissell 3920 Bagless Upright Vacuum
Bissell pet hair eraser vac, beater brush stops spinning when on carpet of any length, belt is new, hose is securley attached and it will only spin like a carpet sweeper while on carpet?
  • 120 Answers
SOURCE: Bissell Pet Hair Eraser Vacuum marking carpet
the brush is always turning on the machine even when your using the tools. try not to set it down on thick carpet , or if you can set it on the linoleum.
Posted on Sep 16, 2009
Vac Belts
  • 701 Answers
SOURCE: the carpet brush on my pet vac will not turn casn
You need to replace the belt. You can get replacement belts and the manual here:
Bissell Lift-Off Belts and Manual
Posted on Nov 18, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
SOURCE: My oxygen will not pick up pet hair out of the. The brush rotates
Your brush may not be spinning try pressing the reset button on the back of the power nozzle, it that does not work you may need to change the belt.
Bob
eVacuumStore.com
Posted on Mar 27, 2010
  • 10 Answers
cheak belt
Posted on May 13, 2010
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
I replaced my Bissell vacuum cleaner belt with a Bissell belt. I ordered it from them so I know it's the right one. I replaced it and the roller won't spin and the belt smells like it burning.
Beckiande485:
You will need to unplug the vacuum from the wall, lay it down so you can see the bottom of the vacuum head and remove the bottom plate (foot plate) Probably philllips head screws. pull up on the roller (called the beater bar). The beater bar will come straight up. Disconnect the belt and check the fittings at the ends of the beater bar... I'll bet that they don't spin easily (The fittings have roller bearings in them, and the roller bearings get gunked up with hair, carpet fibers and dirt). Pull the end fittings off of the roller and remove all of the hair and carpet fibers off of the end of the beater bar and the fittings and out of the bearings. Check to make sure that the roller bearings spin freely. If they do not spin freely, put some rubbing alcohol in the bearing (you can pour it onto the bearing and spin the bearing manually until it spins freely, or you can use a spray bottle with alcohol in it as I do. Once the bearing spin freely, dry them out so no alcohol remains in the bearing, then a drop or two of light machine oil (3 in 1 oil will do) in each bearing and spin the bearing again to distribute the oil. Now would be a good time to check for any clogs in the vacuum head where the hose connects, and check the hose for clogs. Reassemble the beater bar and reinstall it in the vacuum with a new belt, reinstall the foot plate.
Your machine should run like new.
Feb 15, 2013 | Bissell Vacuums
My pet vac only pick up via the tools and the brushes are not spinning
1( test the belt , can be worn, and replace
2( test the power brush and clean, and replace if necessary
3( clearing the hose.
4( see the diagram.
5( test the motor if need Repair.
Sep 06, 2012 | Bissell Upright Vacuum - The Pet Hair...
Will not cyclone any more. brush on botton will
That means that you need to replace the belt. Here is a link to the belt you need and a manual you can view with instructions:
Dec 08, 2009 | Bissell Upright Vacuum - The Pet Hair...
Sep 16, 2009 | Bissell Upright Vacuum - The Pet Hair...
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
Brush won't turn while sweeping
Does it smell like anythings burning if it's on for a while?
It could be that the belt is just stretched out and not keeping enough tension on the brush while its on the carpet. Once you tilt the vacuum up, there's no more friction, so it spins freely. I've had a few that did that.
Oct 26, 2008 | Bissell Vacuums
Bissell 3920 Bagless Upright Vacuum Logo
173 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
