Question about Rule H53sp 24mgra Swimming Pool Cover Pump Centrifugal Computerized
Is there a number to contact Rule directly? - Rule H53sp 24mgra Swimming Pool Cover Pump Centrifugal Computerized
    President:
  • Rule Master
  • 1,378 Answers
The number I have for them is 978-281-0573.
John
Posted on Nov 12, 2010
I changed the battery but the unit still does not come on Efx576i
Beyond looking at the manual BEFORE SERVICING...
Your number comes up as EXERCISE EQUIPMENT... Interesting only because your question is posted under
WEATHER EQUIPMENT...
Doesn't actually matter...
batteries all share the same maladies when
NOT PROPERLY tended...
Take the NEW batteries BACK out ...
test them (first EASIEST RULE)...
Then take a SERIOUS LOOK at the contacts...
if there is nothing OBVIOUS on the contacts... take a softh lead pencil and scribble gently over the high point... re-install the batteries (paying particular attention to their POLARITY)... AND try it again...
Read the manual... reset the unit as directed.
Q-Tip tiny...!!!
If here is OBVIOUS corrosion... comment me back & I can direct a few steps with TINY (tiny!) amounts of vinegar that can be used to remove corrosion... cleaning with TINY amounts of alcohol... and protecting with TINY... TINY amounts of white lithium grease...
Hope this helps!!
Nov 04, 2016 | Measuring Tools & Sensors
How do I get my brush to spin again
Hi Theresa, it's Allan at Dyson.
There are a few things we can suggest to check. The first may seem simple but is often the most effective. Please have a look at the following video which will show you how to dismantle the head and check for obstructions: https://youtu.be/PeTKPc-9DjU
The next thing to try is removing both the wand and floor tool and checking all of the metal contacts for dirt/damage. You can also remove the main body from the cyclone assembly to check the contacts between these two parts. You can view how to do this here: https://youtu.be/RSToNfQoi3c.
After this, try connecting the floor tool directly into the machine's inlet. This will rule out any problems with the connection via the wand.
If you continue to have any problems, please feel free to give us a call - our contact numbers are: 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 28, 2015 | Dyson DC35 Handheld Vacuum
Simple rummy rules
Playing Rummy game is too easy, you just need to know the 3 simple steps:
1. Sort the cards into meld
2. Pick cards, and discard your cards
3. Place the show. ( Sets are 3 or 4 cards of the same number)
Face cards (Jacks, Queens, and Kings) are worth 10 points
visit silkrummy.com to win real cash prizes
Jun 28, 2014 | Toys
Mr.number app how to unblock a caller contact from incoming call
Start the app
touch the circle with diagonal line to open blocklist
touch the X under "exceptions" next to the number to be unblocked
touch "OK" when it asks "Are you sure you want to remove this rule"
May 15, 2012 | Samsung Cell Phones
2004 Ford Freestar SEL real hatch locked cant open. where or how do I find direction to fix
Kathy, You would need a small screw driver and a foot rule or a metal strip about an inch wide and a foot long. Collected? Now, with the screw driver you must remove the plastic moulding that is there on the outer side of the drivers door glass. Just put the screw driver head in the gap between the moulding and the door frame and push upwards. Do it at a number of places and the moulding will come out. After that you must insert the foot rule between the glass pane and the gap in the door over the place where the key hole is directly below it. Push the foot rule down so that you hear a click sound. If you hear it you will notice the door lock has opened. Cheers. Now replace the moulding by placing it where it was and pressing it downwards till the whole moulding is in its place.
Jun 30, 2011 | 2007 Ford Freestar Limited Minivan
How to get an appointment in DFA lucena
Click here --> DFA Appointment
You will be directed to the page where you can set an appointment with DFA. Any Filipino anywhere in the Philippines should set an appointment on the website before going to any office of DFA. That's the new rule now.
But if you want to talk to DFA, just dial (632) 556-000 (mon-fri) 8:00 AM to 5:00 PM.
or you can visit their website @ http://dfa.gov.ph/main/
You can find the appointment button at the right side of the screen together with their contact number if you have some inquiries.
Thank you for using fixya.com.
CARLO
Fixya Expert, Philippines
Apr 27, 2011 | Computers & Internet
New 1800gph pool pump - it cycles every 2 1/2 mimutes but dosnt stay on?
Thank you for posting your question here on Fixya.com.
Sorry to hear you are having trouble with the pump. Since it is new it is still covered by the 3 year factory warranty. You can try to contact the place you purchased it from or go straight to Rule..
Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:
http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf
Or Rule direct at www.rule-industries.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 09, 2011 | Rule 1800 Gph Automatic Pool Cover Pump ...
How do you set up speed dial on the LG OPTIMUS cell phone?
From the LG Optimus S Manual:
Assigning Direct Dialing Numbers
Speed dialing, as available in other feature phones, is
not available. However, you are able to directly save a
contact to your Home screen.
To set a contact as Direct dial:
1. Press (Home Key) >(Menu Key) > Add > Shortcuts > Direct dial.
2. Tap a contact from your Contact List. The contact
will be shown on the Home screen.
Direct Dial-
Simply tap the contact on the Home screen.
Jan 04, 2011 | LG Cell Phones
I am asked to find the log of 6.02 X 10 to the 23rd power> How can I find 10 to the 23rd power?
Why complicate matters for yourself?
You were asked to calculate log(6.02x10^23), let your finger do the calculating.
I checked the claculator manual and you have to enter it all at one go. Pay attention to the key strokes. You will not do it in such a laborious manner
23[10^x] [=] gives 10^23
23[10^x]*6.02 [=] multiplies 6.02 by 10^23 to give you Avogadro s number.
To find its logarithm in base 10, you have to enter the number then press [LOG] . When you press [LOG] you are calculating the log of the last result. You obtain 23.77959649.
If I had given you the key strokes directly you might have not understood why I do things this way. Now the actual key strokes you enter
23[10^x] * 6.02 [LOG] [=]
If you are only looking for your result, you are done. You can ignore what follows.
If you know the rules for the logarithms, you can do the calculation more easily. log here is log in base 10
Rule 1 Log(a*b)= log(a) + log(b)
Rule 2 Log(c^n) = n* log(c)
Rule 3 log(10)=1
Thus applying the rules
log(6.02*10^23) = log(6.02) + log(10^23) first rule applied
= log(6.02) + 23*log(10) 2nd rule applied
= log(6.02) + 23 3rd rule applied
= 0.77959649 + 23= 23.77959649
Hope it helps
Oct 10, 2009 | Texas Instruments TI-30XA Calculator
Torque spec for changing oil filter?
wipe off mating area on the block, then a good rule of thumb is to put a light coat of oil on the filter gasket, screw it in till the gasket touches and then turn it another 3/4 turn. i dont think there is an actual torque spec for an oil filter, oil filter housing yes, but not the filter. the filter should also have directions. most have a number sequence on them and say basicly what i said but they say turn ontill you get to #? hope this helps. bill
Aug 18, 2009 | 2004 Chevrolet Cavalier
Rule H53sp 24mgra Swimming Pool Cover Pump Centrifugal Computerized Logo
51 people viewed this question
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
