Question about Volkswagen Golf V Vw Scale Diecast Model
I have a 97 Passat vr6, and when I shut the engine off the cooling fan keeps running. It killed my battery, got a new one and as soon as I hooked up the new battery, the fan kicked on. Which is more likely that it is the thermostatic switch or the fan relay that is causing the problem? Or could it be something else
    Genius:
  • 1,672 Answers
The FAN RELAY got BURNED CONTACT and it weld itself to giving live power to ur FAN! Look for it and pull it out, that'll stop ur FAN! Replace that relay! Taaah!
Posted on Nov 10, 2010
Engine fan keeps Running After i shut it off
hi I had a Volkswagen golf tdi the fan would run after it was switched off. I think its to cool the engine down . don't think its a problem leave it for a couple of days and see.
Oct 27, 2013 | Volkswagen Passat Cars & Trucks
Have a 97 VW Passat VR6, it died one day as the check engine light came on, it would run for a few minutes and then die, running shorter each time. Took it in to the shop and got the fuel pump replaced,...
You need to check fuel pressure at the fuel rail.if pressure is at spec. Check spark at the plugs. Also replace relay for fuel pump if it isn't working. Could be a bad new fuel pump. Pull the codes first.
Jun 19, 2017 | 1997 Volkswagen Passat
1996 Vw Passat GLS 2.8L; When I turn the engine off the fan keeps running and is draning the battery? What needs to be looked at?
The fan should still run if the engine is very hot,even after most cars are switched off. The battery may be on its last legs.Try this test, before you switch off the engine,put your heaters on full speed,open your windows if you cant stand the heat lol.This should help cool the engine and help shorten the time your engine fan needs to run to bring down the temp. If the battery is still draining,the alternator may be the culprit. This can be tested with a multi-meter.
Jul 04, 2010 | 1995 Volkswagen Passat
I have MIL woes with my 1999 Passat VR6 manual 5 speed. OBDii diagnostics is indicating bad cats. The cats were replaced by a previous owner with after market units and are welded on. My mechanic said it...
yes the exhaust system from 97 will fit with 99 they are compatible but removing it and replacing it with new is bit mechanical job.a professional technicians help is very much required in this time consuming job. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Apr 17, 2010 | Volkswagen Passat Cars & Trucks
The cooling fan keeps running on draining the battery
A STUCK CLOSED COOLING FAN RELAY WILL CAUSE FAN TO KEEP RUNNING.REPLACE COOLING FAN RELAY.
Apr 13, 2010 | 1995 Volkswagen Passat
Cooling fans will not turn off after vehicle is shut down. have to disconnect battery 2003 volkswagen beetle with 2.0 engine
MOST OF THE TIME WHEN COOLING FANS KEEP RUNNING WHEN ENGINE IS OFF.ENGINE RUNNING HOT.YOU COULD HAVE A DEFECTIVE WATER PUMP.THERMOSTAT FAULTY AND THE RADIATOR CORE IS BLOCKED.CHECK GRILLE FOR RESTRICTION LIKE LEAVES AND OTHER DEBRIS.HAVE YOUR CAR HOOK TO A SCANNER THAT WILL TELL YOU YOUR COOLANT TEMPERATURE.THAT WAY YOU WILL KNOW ITS THE THERMOSTAT.
Sep 28, 2009 | 2003 Volkswagen New Beetle Convertible
97BMW 318i fan runs and drains battery when car is off
Yes pull the cooling fan relay in the fuse panel. It might be bad.
Sep 28, 2009 | 1997 BMW 318
2001 passat electric fan runs continously until battery is dead
There are extra cooling pumps that some foreign cars have that run for a designated time after the engine is shut off. I had a Mini cooper made by BMW that had it. If you hear it running for a while, but then it shuts off, thats normal. If it stays on for ever and never shuts off, I honestly don't know what to tell you
Apr 25, 2009 | 2001 Volkswagen Passat
Electric fans runs after car is shut off, drains battery
Having the fan run on for a bit after the engine has stopped is not abnormal in itself, but 20 minutes sounds excessive.
If the fan does eventually shut off, I'd consider changing the thermoswitch (this is a sensor screwed into the radiator somewhere near the bottom, with a pair of wires connected to it - to change it, you'll need to drain the cooling system).
If the fan stays on continuously until the battery is completely flat, see what happens when you unplug the wires from the thermoswitch. If this stops the fan, you need to replace the thermoswitch. If it doesn't, then you need to examine the wiring associated with the switch and the fan, looking for damaged insulation.
A.
Nov 28, 2008 | 1999 Volkswagen Passat
Fan keeps running after engine is turned off
why does the cooling fan start working as soon as i start the car and doesn't shut off until i turn off the car?
Oct 05, 2008 | Mitsubishi Lancer Cars & Trucks
Volkswagen Golf V Vw Scale Diecast Model Logo
170 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
