Question about Line 6 Spider Iii 30
Sometimes my Line 6 stops putting out sound in the middle of playing. To remedy my problem I turn the amp off then back on a few times. Everything lights up as normal when turned on. Also, the main problem is when I swap settings the amp will stop making sound. What can I do to fix my amp?
  • 643 Answers
First open the amp up, and check the connections to the speaker are ok, if that checks out, next is the fuse, you need to check all the components to see which ones are shorting out or overloading. most you can check with a simple voltmeter. this should help you identify your problem.
Posted on Nov 11, 2010
Lo, i have a fender frontman 65 r, bought it 2 years ago, my problem with this amp is that it produces disturbing like thunder sound at the middle of my playing, i checked and change the cable and also...
It could be dirty interupt contacts on the jack you are plugging into. Spray some conct cleaner from the back side and plug and unplug a few times to see if that clears it up. Also spraying the controls and switches- make sure you get the spray stream into the switch or potentiometer to get on the contacts to disolve grime.
Other potential sources are poorly soldered connections on the amp chassis- litterally anywhere. Reflowing all solder connections would likely remedy the problem.
Also make sure the nuts that retain the jacks to the amp chassis are snug and will not move.
Apr 01, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Just purchased a new Line 6 HD 400 from the local GC store. Brought it home, powered it up and connected everything as described to play through an amp and there is no sound out put. I went to the website...
I've had both very good and very bad customer service from Line 6 over the years, Personally, Id take it back to GC and have them explain what you need.That way if it's a case of a defective item, they can replace it on the spot,
May 13, 2017 | Line 6 POD HD400 Guitar Multi Effects...
The amp will suddenly change sound adding reverb,slap back and bad distortion. I have to stop playing and turn it of and back one to get it to play corectly. Very frustrating when playing live....
Likelythe connections and or jack for the foot pedal control are making poor contact resulting in triggering these other modes. If not using the foot switch, probablly the problem is poor contact of the switches on the jack.
Jan 13, 2011 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Sometimes when I turn it on, no sound comes out but the input is picking up everything. It always starts to work again if I wait for quite a while but is there any other way to get it started again?
output caps are failing.
get them replaced by a professional, unless you know how to safely discharge a capacitor without killing yourself with hundreds of volts. i would recommend to pull the chasis out and send it into line 6, a local amp shop may not be equipt to repair it and potenially cost you more time than just sending it in. also, it will cost the same at the factory
yostamplifier.com
Jan 20, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
Spider III amp stopped making sound
After making sure your guitar cable is OK (they often cause the problem) check the inout jack on the amp. They often get broken by yanking cable sideways.
Oct 26, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
I don't know....
As you know, when you plug in your headphones, the amplifier cuts the sound to the external speaker, routing the signal through your headphones instead.
When you accidentally pulled the headphone plug from the jack, it apparently damaged the jack, which has the relay attached that routes the sound to your headphones.
Replace the jack, and everything may be OK. I say may be, because the jack is attached to a circuit board in these line 6 ampllifiers, and if you have damaged the circuit board, you will have to send it to line 6 to be repaired.
The downside is if it is not under warranty, it is an out of pocket expense, and Line 6 will not even give an approximation on how much a fix will cost. I have gone through it with Line 6 in the past, so I am very aware of the procedure. It is also a limited warranty, and they may not cover this particular damage.
However, if you are straight with them and they feel obliging, they may fix it under the warranty, if it is still active on your amp.
I had a spider 2 x 12, which was switching between amp models by itself, and they told me that because it was not under warranty, that I might want to consider NOT sending it to them, and just buying another amp. I didn't like that advice, because they seemed as though they didn't care about retaining my business.
Now, something to consider is taking it to a reputable amp repair shop (preferably one that is Line 6 authorized), and see what they can do. Maybe your clip is just bent, not allowing it to spring back from the contact switch that cuts off the main speaker. It could be a very inexpensive fix, but you need to have a shop actually take a look at it up close and personal.
Good luck. I, for the most part, enjoy Line 6 products, and their excellent distortions. Just remember, their amps tend to have a LOT of problems. You can find sites that list many many dissatisfied Line 6 amp owners. All that electronics (on board effects, soft buttons and switches, etc.,) make them vulnerable.
Now I mainly use my old reliable Marshall 1/2 stack with my Line 6 pod, as well as quite a few other pedals.
You would be amazed by the fact that you can still get pretty good money for a broken line 6 amp, maybe get something with less bells and whistles to break, and go with off-board effects pedals and processors.
Please excuse me for adding my own opinions, I am quite well versed in this type of advice having grown up in a luthier / guitar shop and have been playing for 38 years.
Good luck with everything, and if all goes right, adn it is just bent, it may cost you as little as a few dollars to fix. I'll keep my fingers crossed for you.
Thank you for using FixYa.
Sep 09, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
No power is going to my amp
This sounds like there may be something loose inside of the amp. Please dont go pokeing around in side there your self. Unless you are a fix it kind of person. There could be electric charges , even if it has been unpluged for days. Have some ck. it out if you can not. I bet ya its not to serious , all so ck the fuse. Some times they will play around just befor they blow out for good . keep on playing DFD
Mar 29, 2009 | Line 6 Spider Iii 30
After hour of playing the amp starts the effect popping sound
there is an open connection, most likely right off the input jack ,causing this issue. Resolder it or retension the jack connection.
Jan 29, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Line 6 Spider Iii 30 Logo
122 people viewed this question
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
