Question about Whirlpool Duet GHW9150P Front Load Washer
It gets almost top the end of the washing with "estimated time remaining" as 2 but it has not finished draining or spinning. The machine will not let me start another load or cycle
  • Whirlpool Master
  • 8,220 Answers
It is probably getting a suds reading. If the control senses excessive motor amp draw then that could mean too much soap. A built in program (you might call it the 2 minute warning) in most front loading machines will try and resolve the problem. It could also mean you have junk in the pump filter. The tech sheet is under the bottom panel. Consult it concerning the final countdown. It gets almost top the end of the washing with - themobilian_66.jpgthemobIt gets almost top the end of the washing with - themobilian_68.jpgs=themobilian_68.jpgthemobilian_69.jpg
Posted on Nov 10, 2010
Washing machine won't drain/spin
the program board is not progressing the wash cycle to drain / spin
call in a technician for a proper diagnosis and quote
Aug 02, 2016 | Washing Machines
The digital timer on the machine will say 1 minute to go, but the machine will run on the spin cycle for 6 to 8 minutes before it finishes. Is there a part I can replace to correct this problem?
Your washer displays an estimate of time remaining in the current wash cycle. That estimate is based on the load finishing without any delays. Prior to going into a high speed spin, your washer "tests" the load balance by either rocking or slowing rotating.
If it senses and off balance condition, it will attempt to "rebalance" the load by itself and then retest, rebalance, etc. until it is satisfied that the load is as balanced as possible. Then it begins to spin. When your washer takes longer than is predicted in the display, it is because of this.
Happy washing...
Jan 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
After the washing finishes,water in drum remains
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Washing Machines
Washer goes through wash cycle but will not drain, spin and buzzs. Time remaining shows in display. Unplugged and plugged back in again and buzzing continue and time still shows in display. Help!
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
