Question about Dryers
Heats for a while the makes a noise and stops heating
Dryer heats up then after about a half hour it goes cold. It also makes a rattleing noise when the igniter comes on. At that point the gas valve must not be opening because the is no flame. Could this be the gas valve or something else. please help
  • 525 Answers
You don't provide me with a brand, or model number, so I can only give you limited information. Fortunately, most gas dryers have common similarities in this regionIf your ignitor is coming on and no gas is being emitted, then you most likely have a gas valve solenoid failure. Below is a link to a parts breakdown with imagery and installation help. Item# 3479
Always make sure the power and gas is off before servcing!
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Please rate my advice based on the assistance that helped resolve the issue of your product.
Thank you,
Dave E. (Illeagle)
Posted on Jun 17, 2008
I have heating cooling unit ASU9RQ. When it works for a half an hour it starts to make a ticking noise that comes and goes.
This could be condensation coming from the coil or expansion valve closing because heat load has been reduced after half an hour causing the liquid refrigerant going through the coil to make a bit of a noise check gas charge to be correct this also is a common cause
Jul 03, 2011 | Fujitsu 24R1 Air Conditioner
Loud rattle noise started on cold start up but goes away.Now makes noise on/off throttle all the time.Sounds like cat internals or heat shield,inlaws have same car,same noise
Sounds like the Cat could be bad. Get under the vehicle and hit the cat with your hand. If it rattles then you know what your problem is, if it doesnt rattle then start check the belts and tensioners
Jun 22, 2011 | Suzuki XL7 Cars & Trucks
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
My gas dryer is not heating up and is making a loud rattle noise.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 13, 2010 | Kenmore 73952 Gas Dryer
My dryer only heat up for about 5 min. then it start to make a rattling sound
Hi, Could you get me a model # so I can see exactly what machine you have please?
Does the rattling noise sound like a fast chatter with metal or is it a dull plastic sound?
Thanks
Vic
May 30, 2009 | Dryers
Whrilpool gas dryer lgn2000jqd stops heating half way
u have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
May 12, 2009 | Dryers
A rattling noise from the engine bay
Check the heat shields on the exhaust system. They get loose from the extreme heat fluctuations work loose and rattle. Especially the one between the engine and firewall where the 02 sensor screws in. It probably rattles less after warm up because heat causes expansion which makes it tighter. Hope this helps.
Apr 05, 2009 | 2003 Toyota Corolla
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
gdhi64
Feb 13, 2009 | Whirlpool LGR5636L Gas Dryer
Heating Problem
If this is a gas dryer, you probably have bad valve coils, they can work intermittently, usually for the first part of a cycle, but when they heat up the internal resistance gets too high and they fail to open the gas valve. Once they cool off, (by continuing to air dry) they will work again for a few minutes. They will also make a buzzing/rattling (maybe "metal" ) noise as voltage is applied. For any Kenmore gas dryer, get part #279834 it contains both valve coils. Very easy to replace. Another possibility is that your duct work is plugged, check airflow. Hope this helps.
Sep 14, 2008 | Kenmore Dryers
Dryers Logo
102 people viewed this question
Top Dryers Experts
