Question about Whirlpool AKZ159IX Oven
No Power, DEAD
Hi
I just got back from holiday to find my oven is broken.
There is no green lights on the LCD screen. It wont switch on, nothing!!!
Ive checked the mains and the cooker lights work from the same panel so im guessing its internal.
Anybody HELP!! cant afford call out charge.
Rich
  • 95 Answers
I would pull the stove back, first to check the plug, and then, the cord. If all is well, and breakers are good, you might need to call, then
Posted on Jul 11, 2008
Oven light and elements dead only fan still working where do i find the fuse
Hi, if the fan is still working than i don't think its a fuse as everything would be out . You have to check the oven light and see if its element in the bulb is still ok, if thats ok then you have to look at the elements as they don't last for ever . Some elements can blow a hole in their surface and that's how you know it's broken but some elements are broken inside the element cover and you can't see it . You just have to get it checked out . Mind and disconnect the power before touching or working on the appliance.
May 19, 2016 | Ovens
My oven wont turn on the powers on but the fan won't turn on but all the lights and buttons work and I tried to access the micro switch but can't find it help please as I gotta cook a roast soon
Your oven fan it is dead.That why your oven is not functioning.By replacing the oven fan,the oven should power up and work and function again.
Jan 02, 2013 | Ovens
Oven wont start
I understood that the oven does not heat.
If this is a gas oven start checking from igniter and coils. With electric oven check the thermostat.
If the appliance is completely dead (no power at all), start checking from power cord, progress to relay board (if present in this model), then test electronic control or switches.
Regards.
Ginko
Dec 04, 2011 | Neff Ovens
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
The oven trip switch was tripped last night. After I swirched the switch back on the oven won't work. The lights and the stove are both working and the gigital screen is working.
If you were using the oven at the time it is likely that a short circuit occurred in the element causing the circuit breaker to trip. After switching it back on the oven wont work. You probably need to replace the element.
The switch may have tripped for another reason. If it did when you turned the power back on the electronic clock/timer generally reverts to the auto. function. You need to set the clock/timer back to manual so that the oven will work.
Feb 10, 2011 | Bosch Ovens
No power on the disply panel
replace the control clock its shot...you may be under warranty,,check the last page in owners manuel,,,
Dec 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool RBS305PDQ light does not turn off
It's possible, but is door installed correctly? Push in light switch and see if error goes away. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Whirlpool RBS305PDS Electric Single Oven
Electrolux Oven EOB6630, similar to above
Hi, I've had a similar problem with my electrolux EOB4633. I've replaced the "thermal cut out unit" and it's working now. Basically this unit switches on the outer casing fan ( on top in my oven ) to keep the casing from overheating. When the thermal cut out doesn't work it fails to switch on the fan and the casing overheats, the oven then cuts out completely until it has cooled down and the cycle starts again.
The bit to be replaced ( part no 8996619267611 ) is located on top of the oven, under the outer cover, just behind the timer & selector switch. It's a small ( 1inch long ) silicon sleeve with 4 wires coming out of it, just unplug the wires and replace it with the new one ( unplug/disconnect the power to the oven, or switch of the power at the mains switch first ), then remove the oven outer top cover ( all you need is a screwdriver ). You'll see the offending unit, probably tie wrapped to one of the wire bundles, quite easily - mine was blackened and charred.
Jan 29, 2008 | Electrolux EOB6636X Ultrafan Electric...
Whirlpool AKZ159IX Oven Logo
97 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
