Question about Dell OptiPlex GX260 PC Desktop
Amber power light remains lit. Nothing else happening. Can't even "force" power off. Must pull electrical power cable to make light go off.
  • 1,179 Answers
I suggest going through my tip pertaining to this matter, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!! this should guide you through the process and get your PC going again.
Thanking you
damnor01
Posted on Nov 10, 2010
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
Computer will not turn on. Amber light stays lit.
possibe bios crash you made need to earth the main power cap to see if it is a power fluctuation fault
Jul 14, 2014 | Dell Inspiron 530 Desktop Computer
HP 2000-410US when turned on the power light button blinks 1 time every 5 seconds, nothing elas
1. Disconnect anything that is connected to your laptop. Usb Flash discs, External HDDs, Wireless Devices using dongles etc.
2. Make sure that your device does not receive any power i.e. Disconnect your ac cable, and remove battery from your laptop.
3. Hold down the power button for 5 seconds. This would drain remaining power from your laptop. But as the power cable and the battery are disconnected, you should not expect anything to happen.
4. Identify where your RAM is located under your laptop. Unscrew the cover off, then remove the RAM from your laptop. Replace the cover temporarily.
5. Flip over your laptop. Connect your power cable to the laptop, NOT THE BATTERY NEH! Then press the power button. Sometimes your laptop will make long beeps to let you know the RAM is not inserted in your laptop. But nothing will happen on your monitor because it needs RAM to show you something.
6. After those beeps, remove the power cable. Press the Power Button to drain remaining power on your laptop. Flip the Laptop and replace the RAM you have removed earlier.
7. Insert your power cable and try restarting your laptop and see what happens. I am sure by now you should have some response on your laptop monitor.
NB: While performing the above mentioned, remember PC or Laptop parts are delicate. Even static electricity can damage them. Thus before handling your laptop components, make sure you touch the wall or any large metal subject from time to time to discharge the static. Wear 100% cotton cloths as you are working on it. Bare feet even better to discharge the static
Jun 14, 2014 | Gateway MX8711 Notebook
Bluetooth indicator is not lit despite I switch the wireless ON
Confirm the phone number where you would like Verizon to call you. We will call you momentarily to connect you to our automated system. You can also call us at 1 (800) VERIZON (1-800-204-4427).
Apr 13, 2017 | Dell Latitude D830 Notebook
TV not working when turned on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 18, 2017 | Maxent MX-27X1 27 in. HD-Ready LCD...
Dell 4700 blinking amber light. nothing else happens no fans no beeps.
HERE is the troubleshooting section for your PC from dell. It will give you at least a strating point as to what the problem may be. If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Apr 27, 2011 | Dell OptiPlex SX280 PC Desktop
My GX520 was shut down as usual last night...I turned on this morning and I get nothing...just a little yellow/amber light blinking where it is normally green....help
Here is the info straight from Dell. looks like you have an internal power issue. You will most likely need to contact Dell directly for assistance, they are pretty good about giving support even if the system is no longer covered under warranty.
If the power light is blinking amber -
The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Dec 28, 2010 | Dell OptiPlex GX520 PC Desktop
Amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
Nov 10, 2009 | E-Machines W3503 PC Desktop
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Amber light remains lit at all times
Did you try to replace the battery?
Nov 25, 2008 | HP iPAQ hw6915 Smartphone
Dell OptiPlex GX260 PC Desktop Logo
57 people viewed this question
Alun Cox
