Question about Samsung RS2534 Side by Side Refrigerator
My freezer stay at 8 degree, but fridge is saying 56 degrees. my milk is warm.
    Problem Solver:
  • 9 Answers
This can be caused by many things, there is a sensor that tells the PCB what the temp in the refrigerator, there is a sensor that tells it when to defrost, there is a thermal fuse, there are heaters in the refrigerator. there is a defrost damper that closes during the defrost cycle that can freeze or fail, I saw a guide on the online auction place, E b a y that may help. The first thing I would need to know is if there is ice build up on the condenser. If this is the case the the fan is being chocked off and can not blow cold air through the condenser. If your freezer is fine then the compressor is good since this is a dual condenser unit so no worries there. There is no damper between freezer or refrigerator. Look on e b a y for the manual i think it will help.
Posted on Jan 29, 2011
What termperature should the refrigeration and freezer be at when running right? In degreees, please
Fridge 4 - 8 degrees C, 5 degrees preferred, though some say 1 - 5 degrees.
Freezer minus 18 to minus 30 degrees C with minus 25 being preferred.
Sep 10, 2017 | Refrigerators
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Westinghouse fridge warm freezer -25 degrees
ok the freezer should be at 4degrees f and the fridge should be at 37 degrees f...sounds like the compressor electronics need to be replaced
Jan 10, 2014 | Refrigerators
Ge Profile fridge Model #PSC25MSTASS Wacky temps in Freezer for several weeks, so much so that ice will not stay frozen, so we just shut the ice maker off. Most of the other foods would stay frozen,...
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Sep 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Profile- Freezer/ Fridge at 56 wont go cooler!
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Samsung RS2534 Side by Side Refrigerator Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
