Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer heats up but close remain wet - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Nov 11, 2010
Series 80 dryer not holding a flame. the flame lasts 1-2 minutes then goes out. IT IS NOT the gas coils because i just replaced them. the thermal fuse gives me a beep from my multimeter. i ordered one
Must be the control thermostat. Note: them coils only stay on a brief period of time. They do not stay on indefinitely. The duration depends on how many wet clothes are in the dryer etc. The least amount of resistance to heat the quicker they shut down. The way it works is temp is maintained between 140f and 105f by doing a series of burns for breif amount of time. The coils do not remain on for very long. If they did the clothes would burn up. You need to remove inspect and clean the filter chute. Probably clogged. The dryer must be put back together for testing with damp clothes in the drum and the door closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2013 | Kenmore 75944 Gas Dryer
The top of my get dryer is extremely hot, the dryer is turned off. The only way to cool in down is unplug it. As soon as I plug in back in it gets hot.
the only way that machine is hot is by two alternatives:
se the diagram a) The contacts L/H is closed all the time, they are NOT open, this close one side of the heating element b) The centrifugal switch of the motor is defective, remain closed all the time and NOT open, this close one side of the heating element.
God bless you
Jun 09, 2012 | Dryers
Hello, I have a problem with my AEG Electrolux Dryer T59820. I worked perfectly until... It looks that works OK but all what put inside wet, remains still wet after finish of program. I have tried several...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 01, 2011 | AEG T57800 Electric Dryer
I came home and my dryer had still been running for the whole time I was gone, about 4 hrs. The clothes inside were cold and not dry. This morning I tried getting it to work, but the clothes remained...
heatman101
Apr 23, 2011 | Roper Dryers
Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer runs and spins but does not heat up -the clothes remain wet. Lint is not the issue . Iclean the lint trap every load. I also vacuumed out the coil vent ...
heatman101
Apr 03, 2011 | Dryers
No heat
the first thing to check is that you have 220VAC at the plug. If one leg of the circuit drops out you can have this symptom.
Apr 20, 2010 | Bosch Axxis WTA4400 Dryers
Won't heat. and i cant locate the fuse
my dryer doesn't heat up to dry the clothes. The drum is running but there is no heat - the clothes remain wet. Any ideas?
Apr 17, 2010 | Whirlpool LER4634J Electric Dryer
Not drying and vent hose is wet in the inside gas comes on!
You have what I call a humidification problem and there is probably something clogged up in the hole in the wall to wherever it goes outside. It could also be that the dryer is TOO CLOSE to the wall.
PLEASE NOTE: If the HOT air that the dryer creates is restricted from exiting the dryer, the dryer WILL NOT HEAT PROPERLY.
If you have a CLOO in the ventilation system, the heat will try to get out and it cannot. The distance from the dryer to wherever the CLOG is could bu SUCH that this clog will creat a humidification factor that actually creates humidity and all seems wet.
Nov 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer Changinf time on cycke
Is this on timed or auto dry? Try this with the door open, find the moisture sensor and with wet fingers using the dry finger on other hand to hold the door switch start the dryer and using wet fingers place on both sensors, if it doesnt change to damp or wet it could be the sensor or the user interface.
Aug 10, 2008 | LG DLE2514 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
