Question about Performance Teknique ICBM-Double 6.5 in. Car Monitor
What´s the code number to
Bluetooth pairing
its so simple just pair your bluetooth on your laptop to your mobile when its asks for code just press number 1 and it will asks again on your mobile and press gain number 1....its done..
Apr 27, 2013 | Nokia 6120 classic Cellular Phone
Phone pairing bluetooth
When you want to pair bluetooth you have to add a number in your mobile and the same number should be entered in the mobile which is getting paired with your mobile. This way pairing is done and data is transferred using bluetooth.
Jun 24, 2012 | Samsung Galaxy S GTI9000 Smartphone
How do you pair the phone with bluetooth
pair the phone with another bluetooth phone by putting the same code on other bluetooth mobile setexample 0000 or 1234 or any one else but this code must be put on the other set also for pairing
0000 on mobile 1 ----------pairing----------------0000 on mobile 2 (sucessfully paired)
0000 on mobile 1------------pairing---------------1234 on mobile 2(error can't be paired)
Nov 30, 2011 | Cell Phones
I am want to set up my mobile on my car's blue tooth but the mobile instructions are in Arabic. Can you advise where I can get an English version.
Well, you can always use Google to search for the manual. Search ´Car manual in English for (Your Car model and brand)´ However, from experience, you have to activate the bluetooth connection in your car and on your phone. This can be done from your settings. The next step is to search for devices from you car´s bluetooth. It will find your phone and click it. It will then ask you to type in a certain number displayed on the screen. Use the code and your bluetooth should work. Hope this helps.
May 10, 2011 | Cell Phones
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
Please help pair my Explore 233 to a Samsung T-mobile
The default pairing code for Plantronics is 0000 (4 zeros). If you need more help, try their interactive pairing guide: http://www.plantronics.com/media/media_resources/easytopair/
Sep 01, 2010 | Plantronics Explorer 220 Bluetooth Headset...
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Jan 06, 2009 | Logitech FreePulse Wireless Consumer...
I need a instruction maual for a itrax bluetooth device
Pairing With A Bluetooth Enabled Cell Phone
1. The BTCK06 and the Bluetooth enabled cell phone should be within a distance of 3 feet
(1 metre).
2. With the BTCK06 OFF, press the MULTI-FUNCTION Button (The bottom button) for 6 seconds.
The Red & Blue LED's will flash alternatley and the speaker will make a long BEEP sound.
3. The Bluetooth cell phone will search for nearby Bluetooth devices. The cell phone will display the
BTCK06 in the list of Bluetooth devices. If you are using a "dongle" type Bluetooth adaptor,
follow the manufacturer's instructions for that device.
4. Select BTCK06 to add this Bluetooth device into the list of the paired devices.
5. Enter in the PIN Code "0000" and your mobile phone will show that pairing is complete.
6. If Pairing is successful, user will hear a long BEEP and the Blue LED will flash about every
3 seconds.
Nov 24, 2008 | Cell Phones
Car Audio & Video Logo
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
